Old 02-06-2004, 09:37 PM
dog606 dog606 is offline
won't start!!!
I have a '90 mustang lx and it won't start!
I replaced the starter and battery, had the fuel pump checked, now it will turn over but not start up. Seems like it isn't getting fuel!
Someone told me it could be the fuel sensor, but I have no idea how to check it!!
Can someone help me please????????????????????????
Old 02-06-2004, 11:42 PM
eillob's Avatar
eillob eillob is offline
How did you check the fuel pump?
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 02-07-2004, 12:14 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: won't start!!!
Seems like it isnt getting fuel huh? Is it out of gas? LoL. Check the Voltage to your injectors. Has anything electrical been done to the car recently? You may have a short causing high res to your injectors. But start simple, check plugs, wires, button, and cap. May not be getting fire. But then it would just flood out. You may wanna invest in a DMM or run some codes on it. Diagnosis is a headache - AKA job security for techs.
Old 02-07-2004, 12:32 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: won't start!!!
First thing I would do is replace the fuel relay, it's very cheap, like a few bucks. You can find it located under the drivers seat.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-07-2004, 05:34 AM
Mendari Mendari is offline
Re: won't start!!!
Turn the engine over for a few seconds and then pull the spark plugs to check for fuel. If they're damp and fumey[sp] then you're getting fuel. Also, note the condition of the spark plugs. If the fuel pump was previously faulty, you will notice signs of lean fuel conditions on the plugs.
After testing the fuel system, check if each spark plug is carrying an electrical charge.
1996 Jeep Cherokee Won't Start mocojpo2003 Cherokee 16 09-14-2011 04:39 PM
92 Lumina Won't Start ICM Voltage Brndo Lumina 9 05-03-2010 12:37 AM
99 Regal LS stalled now won't start mfraumeni Regal 7 04-05-2010 01:38 PM
99 Saturn SL Won't Start! turtleisland SC/SL/SW 5 08-13-2009 10:52 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
