Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-06-2004, 06:00 PM
timbo114 timbo114 is offline
Question 94 JGC neutral safety switch location
I am having intermittent starting problems. I have been working thru the gears on my tranny AND 4WD shifters while holding the key in the start position to get this vehicle to start.
Where is the neutral safety switch located? If it is in/under the console ... then how is the console removed? I have found no screws or visible hardware to hold the console in place.
Old 09-17-2004, 03:45 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 94 JGC neutral safety switch location
ok what is ur problem does it crank at all? if it does it's not the Safety neutral swtch. if it doesn't, then it coudl be the SNS (PNS), try to pull the gear shifter all the way back and then put back in park (place key in the ON position, and apply brakes, then shift) and try to start if it still doesn't work. then u may have to replace the switch. ussually this works, o yea are u getting a CHECK ENGINE light or anything that would make it something else.
anyways location of switch:
it is on the driverside of the transmission. right where the shift linkage connects to the tranny.
Old 09-17-2004, 03:47 AM
all the way back to 1st gear then back up to PARK, then try to start, sry about that.
Old 09-18-2004, 08:54 PM
KRM KRM is offline
Check this link out should help you out
http://jeepin.com/features/nss/
Keep the shiny side up & the greasey side down and the pedal to the metal.
Old 09-20-2004, 12:09 AM
the Nuetral safety Switch is located on the driver side of the transmission, right by the shift cable lever on the tranny.
