Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-06-2004, 04:26 PM
nappy925 nappy925 is offline
94'gsr turbo problems
i need help somebody....
i have a 94' integra gsr.
.....the goods.....
t3/t4 airreserch turbo
srp 8:5:1 pistons
eagle h beam rods
ported head w/valve job
ported intake
bored out throttle body
8mm spark plug wires
spearco front mount intercooler
stock ecu
stock flywheel
stock cams
aeromotive fuel regulator 1:1 rising under boost
255 fuel pump
luk stage 2 clutch
map sensor spacer
aem cam gears
------problem------
my car does not run hard and i dont know what to do
the car starts fine and idels fine and drives fine intell i push on the gas more than 1/4 to 1/2 throttle. when u push more than that the car bogs out/cuts out. this is also when the car trys to make boost after 1 pound.
the car pulls the harest when the gauge is about 0 to -3 on the vacum side of the boost gauge. What can i do so the car runs hard at full half and quarter throttle? DO i need a apexi afu/fmu/or the whole stand alone computer kit that they sell? I was told all i needed was a boost rising regulator? witch i have its addjustable to 75 pounds of fuel than rising 1:1 under boost. I am running about 55 to 65 pounds of fuel right now. and the gauge drops to about 50 when pushing on the gas???
PLEASE HELP WITH ANY INFO!!!!! THANKS
Old 02-06-2004, 06:49 PM
Z_animal Z_animal is offline
Re: 94'gsr turbo problems
i dont know much about theese cars, but i would say check vaccuum hoses, if the FP is dropping it might be a vaccuum/boost hose.
Old 02-06-2004, 08:07 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
I bet that aeromotive fuel regulator is the problem. Ditch it and get some kind of real ems such as aem, hondata, haltech, etc. At the very least even a AFC hack would make the car run better.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
