Old 02-06-2004, 04:16 PM
triplerc triplerc is offline
Send a message via AIM to triplerc
couple questions about stroking...
okay, figured out what i want to do. planning on stroking a 350 to 383. what is the best i should do though. .10,.20,.30,.40 over? whats better, more reliable, and all the stroker kit im getting is around 600.00 and i got to find me a block.
1. what should i do .10,.20,.30,.40 over?
2.should there be any head work done or will they be fine?
3. i need to find a good carb, and intake and a distributor.
4. How much will a #1 cost? never had it done before.
5. how much is balancing going to cost...
Im not stuiped but i would like to know this stuff yes, going from a 350-383 is not a learners step, im going to have someone do the work for me, i just want to know how much its going to cost. I got a block, heads and all and the stroker kit its self, but i need to know what its going to cost to bore it and little shit like that.. help please///
Old 02-06-2004, 04:32 PM
here is what the stroker kit includes that im going to get..
SILVOLITE CLAIMER PISTONS H3426
HASTINGS MOLY RINGS 2M139
CLEVITE ROD BEARINGS CB663P
CLEVITE MAIN BEARINGS MS909P
MELLING HI-VOLUME OIL PUMP M55HV
FEL-PRO PERFORMANCE GASKET SET 92600
PBM PERFORMANCE CAMSHAFT 290/300 222/231 .468 .480 110 LOBE
PBM PERFORMANCE LIFTER HA817
DURA-BOND CAM BEARINGS CH8
PIONEER BRASS EXPANSION PLUG PE100B
PBM PERFORMANCE DOUBLE ROW 3 KEYWAY TIMING SET 700
PBM PERFORMANCE HYDRAULIC VALVE SPRINGS 3000 (1.250 OD 110#@1.700 300#@1.250 .500 LIFT)
PBM PERFORMANCE CHROME MOLY RETAINERS 501S
PBM PERFORMANCE 7 DEGREE HD KEEPERS
PBM PERFORMANCE CRANKSHAFT 3.750 STROKE CAST STEEL 2 PIECE SEAL (MADE BY SCAT CRANK)
Old 02-06-2004, 11:09 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: couple questions about stroking...
1 - 0.030 over is the best, its a standard, lots of cheap parts, aka pistons and rings, so no custom stuff, less money. and its a number machine shops are used to doing.
2 - if your already droppin the dime, i would spring for at the very least a port and polish and maybe a three angle valve job. not really nessesary, but certainly to your benifit.
3 - for a 383, i would reccomend a 750-800 cfm, unless its a radical street/strip monster. a mild to kinda spicy 383 should handle those numbers fine. intake, edelbrock performer, and a stock HEI distributor would work just fine.
4&5 - dunno, havnet had it done myself, couldnt tell ya.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 02-06-2004, 11:12 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
I laughed when i first read the topic of this thread, but that's because i'm immature.
Old 02-06-2004, 11:39 PM
89IROC&RS's Avatar
LMAO!!!!!!!!!!! dude how did i MISS that????? i just almost wet myself ohhh geezus, i need to go take a piss.
Old 02-09-2004, 09:47 AM
Vlad_Tepes's Avatar
Vlad_Tepes Vlad_Tepes is offline
Gen I'm with bro I thought the same thing....
Yeah yeah I know it looks like grandpa's but wait til I put the LT1 in it
Old 02-09-2004, 12:15 PM
Genopsyde's Avatar
The President
Yes Vlad, great minds think alike don't they....or is that perverted minds???
Old 02-09-2004, 12:52 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
and here i thought i would come in here and learn about stroking...turns out its just about engines, so dissappointed...
Old 02-09-2004, 02:14 PM
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
guilty...
My Project Write-Up
Old 02-09-2004, 04:30 PM
Gripenfelter's Avatar
Gripenfelter Gripenfelter is offline
Honorary Mod
Send a message via ICQ to Gripenfelter
.30 over
AFR or Trickflow heads
750 carb
Costed me $6500 u.s.
Above price includes balancing.
Old 02-09-2004, 08:00 PM
89IROC&RS's Avatar
GEZZUS CHRIST it cost you 6500 bucks to bore out a block and have it balanced????????dude, you got ripped. was that supposed to be 650??????
Old 02-09-2004, 11:19 PM
Vlad_Tepes's Avatar
Gen yeah we do now we just got to figure how to put a blower on it...LOL
Old 02-09-2004, 11:24 PM
Genopsyde's Avatar
The President
no need, once you stroke, it's gonna blow something all over the place
Old 02-09-2004, 11:35 PM
Vlad_Tepes's Avatar
Lmao
Old 02-10-2004, 10:03 AM
Honorary Mod
Re: Re: couple questions about stroking...
Ported heads with springs and valves: $1500
Scat crank, SRP pistons, Eagle H-rods, speed pro rings and King bearings: $1850
Timing chain and Fluidamper balancer: $750
Felpro gasket kit: $400
Melling oil pump: $200
Machining: $450
Camshaft and injectors: $650
Throttlebody: $300
Fastchip: $350
Assembly and little bits and pieces took care of the rest of the $$
