Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-06-2004, 10:09 AM
Pmpjuice824 Pmpjuice824 is offline
94 honda hatch. with B16a2 vtec engine
i gots a problem here...
i got a 94 honda civic hatch Dx with a stock honda motor.
and the 94 honda's come with a hydrolic clutch..
and the b16a2 comes with a the cable clutch..
i didnt buy the engine yet..but i am late feb. early march. and im spending $1900. and puttin it in my self..
so does anyone know how i can get the motor in with out spending any more money on cable clutch brackets.. did any1 do this or knows about it?..please post me sum sugestions...
How to do it ??????????????????????????????
Old 02-06-2004, 03:16 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: 94 honda hatch. with B16a2 vtec engine
Its the gear box and not the engine that has the clutch set up in it.
And the B16a2 whether its the US or Jap spec engine only even came with a gear box with a hydrolic clutch.
It was the older B16a, only sold in Japan and limited numbers in Europe that had a Cable clutch.
If you did however get given an older engine, then you can use a latter gear box, from either a B16, or B18 powered car.
Old 02-06-2004, 09:31 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Yep, what Moppie said. JDM B16A's had the cable transmission. USDM and JDM B16A2 and B16A3 have hydrolic transmissions.
'96+ B16A2's were OBDII and '95- B16A2/A3's were OBDI.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 02-07-2004, 12:37 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Thats the worst explaination of it I have ever heard.
89-91 JDM B16A-cable tranny, OBD 0
89-91 EDM B16A1-cable tranny, OBD 0
92-95 JDM B16A-hydraulic tranny, OBD I
92-95 EDM B16A-hydrualic tranny OBD I
94-95 USDM B16A3-hydraulic tranny, OBD I
96-00 JDM B16A-hydraulic trany OBD II and IIb
96-00 EDM B16A2-hydraulic tranny OBD II and IIb
96-97 USDM B16A2 hydraulic tranny OBD II
99-00 USDM B16A2 hydraulic tranny, OBD IIb
There are other variations out there, but if you have a B16A2 and it has a cable tranny, then someone swapped the tranny.
