Old 02-05-2004, 10:36 PM
Cooz Cooz is offline
Turbo350
I'm curious if the inners of a BOP th350 and a Chevy th350 are the same.
I thinking of dropping a Pont. 400 into an 86 K10. I need the BOP case of the transmission and the output shaft of the chevy tranny for the transfer case. Thanks
Old 02-07-2004, 07:04 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
They should be, but not always are.
Sometimes the internal components of a th 350 were a bit different depending on the application.
For example, the th350 installed for heavier duty applications such as with a Chevy 350 engine had 6 disks in each clutch pack. The lighter duty applucation, such as a Chevy 305 or 6 cyl engine had 5 disks.
I would say remove both shafts and measure. They should be compatible.
