Old 02-05-2004, 09:44 PM
sleslie17's Avatar
sleslie17 sleslie17 is offline
Uh-oh - I have water coming out of my exhaust
I have been troubleshooting my 97 4.3L Blazer for some time now (see thread below - Low/seraching Idle and stalling) but had to start a new thread on this one to get some attention. I keep having water come from my exhaust, and out of my muffler. The water is definitley very clear (not DexCool). Could this be my problem? It stinks too - almost electrical. I pray to God it is not a head gasket - I only have 60,000 miles on it and its driven very mellow.
-Shawn
Old 02-05-2004, 09:54 PM
sleslie17's Avatar
Re: Uh-oh - I have water coming out of my exhaust
Ihad no codes stored according to the reader I bought. I tried new IAC Valve - no help. I unplugged all O2 sensors, no code was thrown, thought I was on to something it seemed to idle nicley, but dropped to 650 again. I tried to adjust idle screw, seemed to hewp, but when I put in gear the idle drops and it feels like it is going to stall - I adjusted idle with it in gear - it just wants to drive fast by itself - thats a bandaid.
Check this out though - I am worried about the water (a good bit) the continues to flow from my exhaust. It is clear (no DexCool). The truck stinks, almost like electrical - the water too. Do I have head gasket problems?
-Shawn
Old 02-05-2004, 10:04 PM
JOEROC JOEROC is offline
Send a message via AIM to JOEROC Send a message via Yahoo to JOEROC
most water from exhaust is condensation its normal
if it is sweet smelling ...worry
is your coolant level low?????
is it using more gas than usuall???
if so try 02 senser
Old 02-05-2004, 10:20 PM
also dont mess with factory settings....
it could also be a clogged injecter
is there a miss fire????
Old 02-05-2004, 10:26 PM
sleslie17's Avatar
Thanks for the replies. My original thread goes into much detail on my entire escapade. The water really is not sweet smeeling. My O2s all seem to be good via the Chilton checkout. No real missfire - just rough running and low idle AFTER it warms up. All sensors good. I am just really worried about the head gasket thing.
Old 02-11-2004, 01:16 PM
88S10Blazer 88S10Blazer is offline
well i have had some of these things happend, i owned a 93' chevy chyenne with a 4.3, an i had a lot of condisation in my exhust, an when i drove it it shot out some water, an continued to do so as long as i owned it. it seems like no threat, but deff. check coolent level,and check for some leaks around the head gaskets
Old 02-15-2004, 08:50 PM
sleslie17's Avatar
Probably a false alrm - no prob with coolant level or oil. Now that I drove it a while the condensation went away. Thanks.
Old 02-15-2004, 09:09 PM
00blazerls 00blazerls is offline
well if it was the head gasket your oil and water will be mixing so i doubt thats it sounds like condensation and thats normal
Old 02-16-2004, 11:57 PM
sleslie17's Avatar
Thanks - just not used to very much condensation in NM. Probably a bit more in the air and more build up sitting in garage running at idle for the troubleshooting.
Old 02-19-2004, 05:17 PM
RUFLYF RUFLYF is offline
I am having a similar problem as well with water coming from the exhaust, but I am losing water from my radiator...i usually have to add water to the radiator every 100 miles or so. I never thought they could be related but, now that a couple people have asked "hows the coolant level?," I am starting to wonder. I never seem to be able to find the water leak underneath the engine, so could this be my lost water leak?
Old 02-20-2004, 07:31 PM
amac209 amac209 is offline
Send a message via MSN to amac209
water is suposed to come out of the exhaust when you burn gas you get water vapor and co2 when the truck is started water will drip out the pipe and muffler there is a small water drain hole on the back of your muffler once the truck is warmed up the water stays in vapor so you don't see it. nothing to worry about here
Old 03-18-2004, 05:00 AM
rachelw81 rachelw81 is offline
Re: Re: Uh-oh - I have water coming out of my exhaust
ok I just want to make sure i read everything correctly...... water vapor is normal? I just bought a 98 S10 blazer when you start it its has no problems whatsoever. If I shut it off and restart it, it hesitates a second and starts up and I get what looks like white smoke (steam?) comming out the exhaust pipe. I checked the oil its clear looks just like honey. Is this just normal condensation?
Old 03-18-2004, 06:42 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Yes, water is normal, it's part of the catalytic converter process... I wouldn't worry about it..
