Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-05-2004, 08:48 AM
JJ052653 JJ052653 is offline
Angry Headlight Switch problem
I have had to replace the Headlight switch 3 times including the plastic connector that attached to the Head light switch. Eveytime I replace switch I find the Plastic connector is melted and causing the Dashboard lights and rear tail lights not to function.
Either the headlight switch is defective (3 of them, I don't think so) or
there is some other problem.
Can anyone give me a suggestion what is causing the problem, what
to look for and how to correct it
thanks Jim
Old 03-15-2004, 09:58 PM
dannyski dannyski is offline
Re: Headlight Switch problem
I've replaced mine 2Xs. Must be some kinda high current going into it. Now I keep the Twilight Sentinel off and manually turn on and off the headlights. No problems since.
Old 03-17-2004, 09:56 AM
Thanks for the input. I don't have the Twilight Sentinel option. What I believed happen, is the dashboard dimmer over a period of time, fails
and cooks the switch, connector, wires and the tiy delphia connectors(which are a pain to get). I had to re-splice the corrupted connectors.
I agree, too amps going through the wires. Great GM design.
Did you know that there was a NHTSB recall on cars with Twilight Sentinel ?
