Old 02-04-2004, 09:01 PM
402K 402K is offline
Question 91 gsx gear ratio speeds
Sounds like a weird question but settle a bet for me. What is the top speed in each gear for a 91 eclipse turbo awd, talon and or lasers?
Old 02-04-2004, 11:02 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: 91 gsx gear ratio speeds
I don't know the gear ratios for those cars since I don't have them, but if you can find them online, there are plenty of online calculators for you to find the top speeds as well. use google, ive found out mine before that exact way.
Old 02-05-2004, 11:32 PM
kjewer1 kjewer1 is offline
AF - Advisor
At roughly 75 mph the AWD will be about 40 in 1st, 60-65 in second, 90-95 in third, based on my datalogged runs. I forget what 4th is, but 5th can get up to 180 with a very high rpm limit. Thats all I can offer. The ratios are all listed on www.vfaq.com though, for all years and types.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-06-2004, 12:37 AM
Re: Re: 91 gsx gear ratio speeds
thanks for the info---At what Rpm are you talking about and did you change the gearing? My 91 eclipse gsx AWD stock only does 25mph in 1st, 50 maybe 55 in 2nd and 75 in third hitting the rev limmiter and a friend said that his 92 laser shifted at 30, 60, 90 and 120 stock? This is why I'm confused about the issue.
Old 02-08-2004, 06:24 AM
AF - Advisor
Stock gearing, and about 7000-7500 rpm.
Kevin Jewer
