Old 02-04-2004, 08:07 PM
crx hf crx hf is offline
Need help setting my timing
Well i took my distributor apart and put in a new pickup coil and control module.But theres one problem i didnt put the distributor back the way it used to be ,so now my car doesnt run like it used to.i know i should of marked it or something so i would know exactly were to put it.Anyways any help will be greately apreciated.
Old 02-04-2004, 08:49 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: Need help setting my timing
you mean you have it rotated? all you do is loosen the three bolts and turn it, straight up and down is center toward the firewall is advanced and the other is retard
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 02-04-2004, 10:38 PM
I thought u needed a gun to set it were its supposed to be.
Old 02-05-2004, 08:08 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
you need a gun if you want it perfectly tuned, but it really doesnt matter to much, just keep advancing it untill the engine sounds right.
KoRnSaQ
Old 02-05-2004, 11:17 AM
JimCRX's Avatar
JimCRX JimCRX is offline
get a timing light, have a friend rotate the dizzy and watch for the red igition mark to line up on the crank pulley
Old 02-05-2004, 02:00 PM
darolh darolh is offline
Re: Re: Need help setting my timing
And then after you're sure it's really warmed up go for a drive try to make the engine knock. If it knocks you'll have to back it off a bit......or start running a higher octane.
91 Civic Si, 04 SVT FOcus, 67 CT90, 91 CT70, 86 Samurai, 89 F250, 72 Witton, 85 Yanmar, 98 Kioti......too many friggin' machines.
