Go Back   Automotive Forums Car Chat > Eagle > Premier
Old 02-04-2004, 07:57 PM
Bill.t Bill.t is offline
Eagle premier extended crank
I have just aquired an eagle premier I got it through safety but it takes forever to start.I roll it over for quite a while then it starts.I thought it was the fuel pump so I put a pump + filter on it new.then someone said it was the pickup so I put it and a new module on.the car runs fine once running except for a minor hesitation when you really stab the throttle.I tried computer,TPS,fuel pressure regulator,the new patch harness from chrysler for the pickup,The dist was full of oil so I replaced the cam seal + changed the cap + rotor.It has 120 PSI compression on every cylinder,+ like I said the car runs good.has anyone run into this.
Old 02-19-2004, 10:02 PM
Joe W Joe W is offline
Re: Eagle premier extended crank
Have you checked to see if there is spark when you first turn the key and does this have a cold start injector?
