Old 02-04-2004, 07:59 PM
raley raley is offline
Send a message via MSN to raley
Loss of Pressure
My passenger side cyclender has no compression in it. Has this happened to anyone else? If so, what did you do to fix it? I'm on a very tight budget so the cheaper the fix, the better.
Raley
Old 02-04-2004, 10:39 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Loss of Pressure
Passenger side cylinder? If that is what you meant then what are you talking about? I would like to help but I am confused as to what you are asking.
Old 02-04-2004, 10:52 PM
miguel6632 miguel6632 is offline
Send a message via AIM to miguel6632
hes talking on the #4 piston and if your car still runs fairly well you can just replace the head gasket thats probably why you have no pressure if you do it your self its not that expensive to replace but a shop will charge you
Old 02-04-2004, 11:28 PM
whtteg's Avatar
I highly doubt it being the headgasket. Probably more like either the piston rings or the valves. Do a leakdown test and listen to where the air is going. ie: I fthe air is going into the exhaust then the exhaust valves are not seating properly, if the sir is going into the intake then the intakes valves are not seating properly, and if the air sounds like it is going into the oil pan then the rings are bad. Have you done a compression test? What were the #'s?
Old 02-05-2004, 05:38 PM
nope i haven't done an tests, i don't know anything about engines! and i'm burning a lot of oil!
Raley
Old 02-05-2004, 06:24 PM
whtteg's Avatar
Re: Re: Loss of Pressure
Raley
So how do you know it is your #4 cylinder?
I would advise you to take it to a shop if you don't know anything about engines. This is not something you can easily learn over the internet, determining what the problem is and fixing it is hard to explain to a person who knows absolutely nothing about motors.
Old 02-05-2004, 06:39 PM
i am going with its the 4th because i was looking at the hayne's manual and it numbers them off. I don't know things about engines specifics. I have rebuilt old Type-3 VW engines and complete cars, but nothing new. Also, i have people around me that can easiely help me, but i was hoping to determan the problem before asking them for help.
Raley
Old 02-05-2004, 06:47 PM
whtteg's Avatar
Do as I suggested in the 4th post compression test and leakdown test. Without these nothing can be determined.
Old 02-05-2004, 10:34 PM
WERD ill be easy to find out like that
Old 02-05-2004, 10:42 PM
so, how do i hook a hose up to that. Just like thread in an air compresser or what?
Raley
Old 02-07-2004, 07:27 AM
I thought of another question, when i remove the head to get at the rings (this is how i'm assuming it will have to be done). Do i have to get a new head gasket and new rings, what else do i need to get? Is there a kit for it or something of that sort and where do i get it at.
Raley
Old 02-08-2004, 12:17 AM
just buy a new head gasket i tryed to reuse one one time and it worked for a month or so and then i had to replace it ...trust me dont go cheap
Old 02-08-2004, 12:48 AM
whtteg's Avatar
Take it to a dealership!!!!!!!!!!!!! You have absolutly no clue what you are doing and you cannot learn everything ob the internet, some one has to show you some of the things in person. Please save yourself some money and take it to a dealership or good shop.
Old 02-08-2004, 07:42 AM
well, i will be getting a swap soon so I'm gunna put in a d16z6, so if i totally trash the engine, oh well! I might learn something. I will not take it to the dealership, the one around here is full of ass holes that know less about cars then i do.
Raley
Old 02-08-2004, 09:22 PM
NO STEALORSHIP they rip u off so bad its not even funny just find a good shop
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 09:39 PM
