Old 02-04-2004, 03:18 PM
cybermoser cybermoser is offline
How to Test a Fuel Pressure Regulator
Does anyone know how to test a Fuel Pressure Regulator in a 1997 Chevy Blazer with a 4.3L (w)? I have low fuel pressure and I am trying to figure out if the problem is the fuel pump assembly or the Fuel Pressue Regulator. Can anyone tell me how to test the Fuel Pressure Regulator? To get to this item I have to remove the upper intake manifold. I would think there would be a way to test that without removing the intake manifold.
Please help.
Old 02-04-2004, 03:55 PM
xjoeharperx xjoeharperx is offline
Send a message via Yahoo to xjoeharperx
Re: How to Test a Fuel Pressure Regulator
Tap into the fuel regulator with a pressure guage..the pressure should remain constant at idle and move up slightly when engine speed is increased.. if pressure drops then regulator is bad..
Old 02-04-2004, 04:43 PM
Re: Re: How to Test a Fuel Pressure Regulator
Do you mean tap into the fuel rail test port (the same port that I used to check the fuel pressure)? If it says 50 psi., (like it does, however is should say 60-66 psi.) and increases when the engine speed is increased, that tells me that the fuel pressure regulator is good. If the fuel pressure decreases when the engine speed is increased the fuel pressure regulator is bad.
Is my above analogy correct?
Old 02-04-2004, 06:06 PM
check the service manual to see what the correct fuel pressure should be...the pressure should remain constant..the regulator keeps the pressure equal at all rpm's so that the computer knows how much fuel is going into the engine...it shouldnt go up very much at higher rpm's...more that 3 or 4 psi..and shouldnt drop more than 1 or 2 when it comes off idle...and yes the port used to check fuel pressure is correct...the vehicles with the vortec motors had a problem with the regulator leaking...after preforming the check turn the key off and watch the gage..if the pressure falls rapidly you will need to change the regulator out..
Old 02-05-2004, 08:02 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
correct fuel pressure is 56-60 for start, 61-65 at running...
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 07:32 PM
'90 mustang will bad fuel pressure regulator cause idle surge? fords4me Mustang Problem Diagnosis 1 11-27-2009 03:18 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 10:09 AM
Testing fuel pressure regulator jeffk388 Grand AM 5 10-23-2007 06:29 PM
testing fuel pressure regulator and crankshaft position sensor sylbry Aurora 1 01-02-2007 05:47 PM
