Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 02-04-2004, 07:57 AM
bambam69 bambam69 is offline
transmission replacement
I have a 1985 w/automatic and a 1986 w/manual. Does any one know if I can replace the automatic with the manual and have it work.
Old 09-20-2004, 08:45 AM
smeghead smeghead is offline
Thumbs up
Hey I have a 88 that had a automatic tranny in it that was blown....It can be done. What you have to do is remove the automatic tranny and the shifter from the floor. Remove the brake peddle..what i did for this was reomoce the hole assembly for bolts under the dashbourd.....remove the flexplate and everything that deals with the auto tranny....there is a pannel under the hood by the wire harness that comes through the firewall that you remove as well and a plug....that is for the clutch....and then do the same from the one that has the standar tranny and install in the other van.....You have to use the drive shaft from the van with the standard too...for it is longer than the auto drive shaft......It took me two day's to change mine over but i think it was worth it...
Old 09-22-2004, 02:40 PM
Re: transmission replacement
Where there any computer issues. I've had a bad time with aerostar computers.
Correct Procedure to R&R transmission on 1996 Tahoe 4x4 5.7L marklar34 Tahoe 0 12-10-2009 12:16 AM
94 Transmission Replacement sullimt Intrepid 3 08-19-2005 10:48 AM
transmission replacement for a '95 3.8l with a 2000 engine joint30 Mustang Talk 1 01-30-2004 05:09 PM
Transmission Replacement Help me! PWRDbyTRD Thunderbird 1 10-09-2003 06:48 PM
Help: Overdrive mode oes not work after transmission replacement yuris Engineering/ Technical 0 05-08-2002 11:44 AM
