Old 02-04-2004, 01:42 AM
crabby760 crabby760 is offline
advancing ignition timing
i was curious about advancing my ignition timing on my b16a motor how safe is it if you do it with a timing gun or a timing light? also does it make a difference someone let me know thanks...
Old 02-04-2004, 01:45 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
it should be perfectly safe to advance your timing, the only thing it might do is fuck up your distributer after a while of use.
KoRnSaQ
Old 02-04-2004, 03:07 PM
ok and how do i advance my ignition timing can i do it my self can someone tell me how and for sure this wont mess up my engine by advancing it? also i want to advance it enough so i can feel a difference
Old 02-04-2004, 04:09 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: advancing ignition timing
It is by far not worth the time. If you advance it enough to notice a difference then you have advanced it enough to risk pre-ignition AKA: Knock. This will destroy your motor very quickly.
Old 02-04-2004, 07:58 PM
advancing hte ignition timing is when you turn ur distributer towards the intake manifold rite?
Old 02-04-2004, 08:28 PM
carrrnuttt's Avatar
carrrnuttt carrrnuttt is offline
Sorry I couldn't answer your PM about this subject earlier, but I was busy with work/school, and dealing with that troll that I dealt with in the street/track forums.
Anyhow, here's my answer: http://www.centuryperformance.com/timing.asp
2002_Nissan_Maxima_6-speed
Old 02-04-2004, 08:49 PM
that website i didnt understand can you just tell me ur self how u advance ur ignition timing and how do you know if its enough or too much?
Old 02-06-2004, 05:22 AM
spooleffect's Avatar
spooleffect spooleffect is offline
Send a message via AIM to spooleffect
The ENTIRE purpose of timing for performance is to get maximum cylinder pressure at the right time(12-14 Degrees ATDC) There are a TON of factor needed to calculate this however. But generally it takes about 20-30 degrees at 6,000rpm to reach this max for an NA engine running on gas. So ~14-18 degrees of advance at 6,000rpm will do this. Of course as rmp increases, the advance will increase. But if you have the timing tuned just right, you'll get great power and most importanly you'll gain A LOT of reliability.
performance effects of advancing ignition timing mtbroadhurst Engineering/ Technical 9 11-05-2005 12:22 AM
Ignition timing advancement Racincc85 Engineering/ Technical 7 11-05-2005 12:16 AM
initial ignition timing advance possible? bigjimslade CL | Inspire | Saber | TL 0 03-02-2005 10:22 AM
How to advance ignition timing? p11_verde Engine 0 07-04-2003 06:03 PM
Advancing ignition timing Primal SMX Engine 6 10-30-2001 09:41 PM
