Old 02-03-2004, 11:50 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Tt 408?
based on boosted331's comments in my thread titled 'cheater nitrous', i'm gonna change my plan. don't think it's possible to get kenne bell to make me a custom s/c capable of feeding my 408. rather than be like every other mustang guy out there and use a centrifugal s/c, i was thinking about twin turbo. that would greatly enhance my street drivability over a supercharger, and would make my 'stang stand out just that much more from the crowd. i mean how many TT notchbacks do you really see out there? especially in the detroit area where i live, which is rife with rice and everybody + their grandma uses nitrous and centrifugal s/c's.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 02-04-2004, 12:07 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
What about a big single? They are cheaper, less moving parts, spool quicker, and will produce the same power.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 02-04-2004, 08:30 AM
sometimes the cheaper way isn't always the best way. even in cases like this.
i haven't researched it in-depth yet, but it seems to me that twin turbo would be more street drivable, given that it takes longer to spool. especially in a 6-speed where controlling torque is important, having less to begin with on the street would be nicer. besides, twin turbo hoods look sweet!
anyway, nothing's definite yet. i've come across some sources i can use to research this. i dont' know how many turbo gurus there are here, but any input is appreciated.
-Andy
Old 02-04-2004, 05:42 PM
boosted331 boosted331 is offline
If you're going twins, I would run a pair of precision PT61's .81 or .96 A/R tang housings, if you're going single I would run NO SMALLER than a "small frame" PT88. A single T4 housing, even something like a T76-GTS would be severly restrictive on something like a 408 which flows a ton of air. If you don't care about PS or AC i'd do a mid-frame PT88 (uses a TV housing and flange, the small frame uses a T4 flange but a much larger housing and wheel than a standard T4 turbo) with a full 5" downpipe, it would make some decent power
Also, FWIW, for a turbo setup i'd go smaller than 408 inches if you want a street car. Any 302-347" motor with a PT76-GTS will be making full boost not long after 3000 RPM's, you could easily squeeze 700+ to the ground out of it on pumpgas (look at brent, 770 to the wheels spinning it to 5000 with 18 pounds of boost on a 302" engine!) but the turbo will push enough air for 900+ on race gas. Using the 8.2 deck 302 just makes it easier to get it in there, easier to buy parts for it, etc.
Old 02-04-2004, 09:25 PM
well, i'd love to take your advice on engine size into account, but my crank just came in the mail today and the block is already .030 over =D. i'm committed. so, i'll just stick with what i got.
i'm not too concerned with lag. it'll be fast enough for me. and more street drivable too, with the 6-speed. i like the idea of twin turbo more than anything else, and it looks killer.
being that this is a street car, it will have power steering, so i might go with 2 independant turbos, if that's possible. one on each side of the engine, with 2 inlet pipes feeding the motor.
i'm not well versed in turbo function just yet. at the moment i'm learning the fundamentals of compressor maps and such. what exactly is a downpipe, and what does it do? should i have a boost controller on this thing so i can run pumpgas on the steet and race gas on the strip? what about inter/aftercoolers?
oh yeah... given my entirely forged bottom end, my block shouldn't have any problems with this amout of power. should i add a girdle just to be safe? how about a windage tray? finally, what would be my best option as far as oil pumps/pickups go? thanks.
-Andy
Old 02-04-2004, 09:40 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
a girdle is always a good idea when adding serious power to an engine. ive heard different stories however about running windage trays w/ or w/o a girdle though so look into it. d.s.s. offers a nice 5.0 main support package for a good price.
what year and vehicle is the 351W block from?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-04-2004, 10:55 PM
Re: Tt 408?
A downpipe connects to the exhaust outlet on the turbo, and then runs down to your H/X-pipe, or simply dumps. A boost controller, especially an electronic one, is a very good choice. A good EBC will keep boost pressure from reaching the wastegate untill full boost is reached, allowing as much exhaust energy as possible to the turbine(s), which results in quicker spool up. It's also nice to be able to adjust boost on the fly. Charge air coolers are usually called intercoolers, although the proper name is aftercooler. An intercooler is used on a multiple turbo diesel setup, where one turbo feeds into another. An intercooler is a charge air cooler placed between the outlet of one turbo and the inlet of another. Check out This Thread about a group purchase on bigass griffin intercoolers, might want to act fast!
The ability of your block to handle power has a lot more to do with the actual strength of the block itself, rather than the internals. I talk to TONS of people that tell me "Oh yeah, I got a forged crank, rods, and pistons along with a girdle in my stock 5.0 block, it'll handle 700 RWHP easy" but that really isn't true. The 351W block is a lot beefier than the stock 302 block, but past 600 RWHP and it starts to become a ticking timebomb, unless you've filled it. The only thing i've ever seen a girdle do is keep all the mains together when the block splits in half, a windage tray will free up some horsepower, and make the motor rev snappier because it isn't fighting off as much resistance from the oil.
Old 02-05-2004, 12:06 AM
so if you're running independant twins, wouldn't it make sense to have a separate downpipe for each turbine? and another question, where am i gonna get intake manifolds to fit a system like this? what about a blowoff valve?
-Andy
Old 02-05-2004, 12:09 AM
SkylineUSA's Avatar
Girddles are a waste of money.
5" downpipe, holly shit that is big.
StangNut86,
With a 408, and a TT set up you are going to have a lot of power, maybe even too much. The volume of air needed for this engine is going to be huge, I mean your power goals are very reachable with the combo that you want, but the engine being streetable might be in jeopardy.
Can you list everything that you have for the car? And what you are trying to achieve? 1/4 mile goals? Suspension?
the block is from a '79 Ford truck, that's all i know. it's a 2-bolt main. of course, the main caps are the beefiest i've ever seen on a motor this size.
boosted, you mentioned filling. i've never heard of this before. what exactly does it entail, and about how much can i expect to pay for it?
-Andy
Old 02-05-2004, 12:12 AM
SkylineUSA's Avatar
Re: Tt 408?
Yes, you will have two seperate downs. Your intake options are pretty limited. To me only one option really, go with a Spyder from coast high.
Old 02-05-2004, 12:36 AM
SkylineUSA's Avatar
79s are pretty good blocks, but since your going to be putting a small furtune into this engine, why not try and going with a better block. That block will be the weakest link.
What fuel system do you have lined up for this beast? What ECU controller? What injectors are you looking at? What gears are you wanting?
Old 02-05-2004, 09:28 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Tt 408?
OK I have a question here?
With a 408 and TT set up, your going to have tons or torque and hp at a relatively low rpm. So there is really no need to run a real steep gear. So I'm assuming your thinking of running 3.55's or 3.73's. Because anything more then that and you'll just be smoking the tires no matter how easy you drive. So with that said, what would the point of a 6-speed be?
I can see a 6-speed being beneficial if you had very steep gears like 4.30's or 4.56's on an NA car that made its main power high in the rpm band, and still wanted it to be street friendly.
It just doesn't make much sense to me, what am I not getting here?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-05-2004, 10:01 AM
SkylineUSA's Avatar
StangNut86,
From what you have mentioned. You have the 408 crank. Why not get your power from a bottle? Boosting is not truely ideal for what you are planning, at least IMHO.
You will have plenty of torque for the lower revs, plus if you want the extra power, its there at a push of the button.
What you are planning, the whole package will not work. I mean,yes it will work, but you could spend less money with a different combonation of parts and make a better car.
Old 02-05-2004, 11:28 AM
Re: Tt 408?
Originally Posted by SkylineUSA
StangNut86,
Which is why I sugested a centrifugal blower Looking on the major mustang websites you can pick up a bare YS-trim or Novi2K kit for pretty damn cheap (under 3K) you'll only really need to adjust the mounting bracket and you'll be set, and it will make a boatload of power. Building a turbo kit for a 351W can be a big pain in the ass routing downpipes and trying to get the headers to fit. If you went with a blower, you could pick up a set of swap headers, drop motor mounts, and be done with it.
