Old 02-03-2004, 11:21 PM
1qwik4 1qwik4 is offline
Send a message via Yahoo to 1qwik4
Master Clutch Cylinder
I need to replace my master cylinder and am looking for instructions, help or advice. I tried vfaq and didn't find anything. I want to know the proper way to remove the master clutch cylinder and install the new one. Any help would be greatly appreciated. This swap would be on a 2g eclipse gst. Thanks in advance.
Old 02-03-2004, 11:36 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Master Clutch Cylinder
do you have the shop manual?
Old 02-04-2004, 03:52 AM
kjewer1 kjewer1 is offline
AF - Advisor
IF any site had it online it wouldbe www.taboospeedshop.com, but I dont think they do. At any rate its not too bad. The tough part is getting that hard line flare fitting off. Be sure to use an appropriate wrench to avoid banjaxing the hex on it. Line/fitting wrench is best, but then its hard to get enough room to swing it. Remove the actuator rod that comes from the clutch pedal. There should be one bolt and one nut/stud holding theunit in. Thats about all I can say. Be sure to bleed properly when you are done.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-04-2004, 06:19 AM
No, I don't have a shop manual its been on my list of things to get. What is a name of a good one, I will try and pick one up today. This is something you could get from an autoparts store, right?
Old 02-04-2004, 07:35 AM
BTW what size is the flare wrench used to remove the flare fitting?
Old 02-04-2004, 08:28 AM
Found a good write up if others are interested.
http://www.plymouthlaser.com/masterc.htm
