Old 02-03-2004, 11:21 PM
jdog86 jdog86 is offline
Send a message via AIM to jdog86
Automatic to Manual help
Ok i have a 91 mustang and was wondering how hard it is to change from the stock auto to a 5speed. And if anyone could give me a link to a page of step by step instructions that would be great.
Old 02-04-2004, 12:32 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
do you know how to weld? the hardest part of changing form auto to manual is hanging the clutch pedal properly. this involves welding the appropriate bracket in exactly the right spot. other than that, just need to make sure the new tranny is calibrated for your speedometer. you can cut the wiring harnesses that control the transmission off entirely. i believe there is a reverse sensor that has to be transferred wiring-wise, but that's easy.
IMO, if you want a car that's manual, buy one that's manual right off the bat.
i believe that all mustangs of a particular year between '79 and '04 have driveshafts which are identical between auto and manual. if i'm wrong, you will have to find the appropriate shaft. that should cover most of it, good luck.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 02-06-2004, 09:50 PM
thanks a lot man been wondering if it was goin to be hard since i bought it. Ya i would have bought a manual instead but you got to take what you get for your first car and i think i came out pretty good.
Old 02-06-2004, 11:37 PM
90Stangjc 90Stangjc is offline
Actually, u dont have to weld anything. All you have to do is buy annother bracket to use on it. First take the driveshaft, tranny, torque converter, flexplate. Then put the pivot bearing in. Then put the flywheel, clutch , pressure plate and throwout bearing. Make sure to get your little line up tool from the nearest automotive store. You can use the same crossmember but it would be easier to use the one from a five-speed, bigger bushing holes. Then run your clutch cable from the fork to the inside of the car. Then put your exhaust back on and then put your shifter in. Put fliud in your tranny, put your pedal bracket on and put the speedo back in. Yes your old driveshaft will fit. Go ahead and take the steering wheel out and driver seat as it will be easier to work on your pedal bracket. All of this should take you around 15-18 hours of suck ass labor. I did in on the wet ground outside using common handtoools, it took me 15 hours in total. This is by far the biggest time consuming bitch i have ever did, if you dont want to do it by yourself it will cost you $2100-2500 for a automotive shop to do it for you including the transmission and clutch, ect.
1999 Camaro Z28 M6- Aftermarket mods- LS6 Intake, Chip
Home mods - Ram Air mod, !CAGS
FACTORY FREAK BIOTCH!
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
