Cheap Good Hp Mods
Hey i have a 90 mustang gt that i am looking to improve and was wondering what are some of the cheaper mods but best HP gains besides nitros and superchargers.
Pulleys are a good mod and fairly inexpensive. After that you are going to have to put some money in it if you want to see some significant improvement. Gears and exhaust are also good mods but they are not what I would call cheap.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator (If it doesn't scare the Hell out of you it isn't fast enough) |
Fast, Good, Cheap: pick 2
Good + Cheap = not Fast Fast + Cheap = not Good Fast + Good = not Cheap
-Andy '89 Mustang 5.0 - How fast? i'll know this weekend. '86 Mustang LX - Shortblock is built, now for the rest of it. "Put the subject before the verb, hmm? Fail this class, you will." -Yoda teaches english class. |
Re: Cheap Good Hp Mods
but if my memory serves me correctly there is already a thread still going about this topic. |
Re: Re: Cheap Good Hp Mods
So here's a basic list of mods, although not always cheap. #1, Gears! #2, K&N with removed silencer #3, short throw shifter, is 5-speed. #4, complete exhaust system. Headers, h-pipe, catback #5, pulleys
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
who makes good gears?pulleys?
March Performance Pulleys makes good pulleys. As far as gears I really dont know.
Gears? U Choose. Precision Gear makes good ones, FRPP, Reider Racing, etc.
Stick with a big name brand and you'll be OK. As long as they're properly installed they'll definitely outlast a T-5...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons..... http://www.cardomain.com/id/mccobra94 1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster. Freedom Isn't Free. |
A Steeda Tri-Ax would be a big improvement over the stock rubbery shifter, I run one in my car now and I have in the past. Gears are probably the single biggest improvement in your cars acceleration, you can also bump the timing up a few degrees, get a cheap densecharger, full exhaust, and some weight removal.
i think ive whored this guys thread to the fullest lol |
You gotta run higher octane fuel. You can also get a short belt to free up a few horsies... just dont run it too long wihtout the short belt cuz the smog pump will seize.. that is if your state requires such smog equipment.. Other than that, k&n filter and removing the air silencer is pretty cheap. Also adjust your TPS for better throttle response. Then if you got the money, get some taller rear end gears, then headers(which go for better mileage as well).
when in doubt, throttle. |
Re: Re: Re: Cheap Good Hp Mods
Don't run a short belt if you still have the stock cat h-pipe. Bypassing the smog pump with cats still in place will only cause the cats to clog up creating a major flow problem. It is highly recomended that you DO NOT touch the TPS sensor to adjust the voltage. The settings stock are just fine and need no adjustment unless you have swapped throttle bodys and the sensor was removed. Then it will need to be adjusted to the proper voltage reading. Improper voltage settings will cause you nothing but problems. LEAVE THE TPS ALONE!!!! Sorry man, didn't mean to pick apart your post, but just wanted to clear up a few things.
Re: Re: Re: Re: Cheap Good Hp Mods
I definitely agree'd with the higher octane thing cuz my car does the same thing.. I don't know why.. Butt I just figured that his car may not be like that, so I just wanted to say it to be safe. I just spoke about the rest of the stuff from magazines I read(like Car Craft), not from experience.. haha.. so ya. n/m my post then.. lol
