Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-03-2004, 09:41 PM
blacktypeR's Avatar
blacktypeR blacktypeR is offline
Question painting my interior
i have the biege interior and i want to paint it black b/c im going to eventually re-do the entire interior in black grey and off-white. how should i paint the interior (plastic and vinyl). please try to be as specific as possible. i want to do it myself because i am very short on money or i would get it professionally done. thanks guys
Old 02-03-2004, 10:38 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: painting my interior
I think there is some paint that is a plastic die in a spray can for that purpose. Have you tried looking at the local parts stores?
Old 02-04-2004, 02:20 PM
HTRtech HTRtech is offline
painting interior
I would suggest heat resistant paint and painting each piece individually and make sure they are clean. VERY CLEAN! and left alone. Two coats maybe necessary.
I will warn you against this if you do not have any supervision (like someone who has done it before). Definitaly seek out a a parts shop or body shop that may offer good advice. It is a delicate process and needs to be done correctly the first time. It gets pretty pricey if you keep buying new pieces to repaint.
Find out what it costs to buy the black stock, in comparison to how much the paint and effort may cost, aswell.
Good luck
Old 02-04-2004, 02:36 PM
vtecteg vtecteg is offline
im looking at coloring my gray parts on my interior andhave found a dye that im going to use. i would say that that would be better no worries of paint chipping
…’°ºV†€Ctëgº°‘…
Old 02-04-2004, 08:03 PM
blacktypeR's Avatar
what is the name of what u are using? and where could i find it? thanks guys for your advice!
Old 02-10-2004, 09:49 PM
tidus32284 tidus32284 is offline
Send a message via AIM to tidus32284
you can use any type of paint, but if you put heat on the panel before you paint it , the paint will bond better, and will be more resistant to chipping, i used spray paint in mine and it took almost 4 months of hard wear to chip it, not to mention it the chip was on the door, so thats my opinion, and its cheap
