Go Back   Automotive Forums Car Chat > Buick > Century
Old 02-03-2004, 09:13 PM
mstngcobrasvt98's Avatar
mstngcobrasvt98 mstngcobrasvt98 is offline
Send a message via AIM to mstngcobrasvt98 Send a message via Yahoo to mstngcobrasvt98
1991 Heating Problems
When car is running, car does not over heat, warm air comes out of defroster vents only even when changing from defrost to vents. Heater core is good, fuse is good. Please help a cold friend.
Just a good model of mine:
2 Fast 2 Furious Skyline
STOLEN!!!
Another go at it:
2 Fast 2 Furious Skyline.. Pt. 2
Old 02-03-2004, 09:23 PM
brooster brooster is offline
Re: 1991 Heating Problems
You have a broken vacuum supply line somewhere in the system. Usually it is located below where the battery sits. You should be able to locate a vacuum hose (1/8" plastic) which runs from the intake manifold to the firewall and toward the driver's side. This hose should run to the reservoir hidden behind the splash shield in the wheel well and below the battery tray.
Old 02-03-2004, 09:50 PM
sorry, i had wrong info at first. Car is a 1991 Oldsmobile Cutlass Ciera. Does this change anything? And does this need to be moved?
STOLEN!!!
Another go at it:
Old 02-03-2004, 10:07 PM
Same answer.
