Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 02-03-2004, 09:12 PM
gabpersonal gabpersonal is offline
01 Yukon XL Lift?
I have a 01 Yukon XL. I want to go move up to a BFG 285 All Terrain Tire. I know that I will need to add a spacer to push the wheel away from the shock mounts, due to increased width. I am also wanting to give my truck a small lift. Someone suggested turning my torsion bars in the front and adding a poly spacers in the rear. Is this the right thing to do, or should does anyone have a better solution. All comments appreciated.
Thanks, A
Old 02-16-2004, 07:24 PM
mut66lax mut66lax is offline
Re: 01 Yukon XL Lift?
torsion bar turning is ok, I did it, then I wanted more so I got a 6inch lift, i suggest looking into about a 2-3in lift if you only want a lil bit, plus then you could fit like 305s on it, at 6in i can fit 315s. The torsions will only take the front up (no more than level is suggested) about .25 of an inch...
