Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 02-03-2004, 09:10 PM
gabpersonal gabpersonal is offline
01 Yukon XL Lift
I have a 01 Yukon XL. I want to go move up to a BFG 285 All Terrain Tire. I know that I will need to add a spacer to push the wheel away from the shock mounts, due to increased width. I am also wanting to give my truck a small lift. Someone suggested turning my torsion bars in the front and adding a poly spacers in the rear. Is this the right thing to do, or should does anyone have a better solution. All comments appreciated.
Thanks, A
Old 02-03-2004, 10:11 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Um, this is a NISSAN Xterra forum, not a GMC Yukon forum. Try the Yukon section:
http://www.automotiveforums.com/vbul...play.php?f=184
Old 02-04-2004, 11:19 AM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Ahh...what the hell. I'll answer.
Yes, you can probably use the torsion bars for a small lift at the expense of ride quality (I'm guessing since I don't have a Yukon). The spacers will screw up the wheel geometry and potentially cause you more/expensive problems and won't change ride height so you might have a low rear end compared to the front.
If you want larger tires and a small lift, why not buy a lift kit? There has to be some out there for the Yukon. Or just get taller tires, but don't get extra wide ones.
Xterra4x4.com and the Xterra Offroad Webring
Old 02-05-2004, 08:37 PM
I must have gotten into the wrong forum by accident. Sorry for the confusion.
