Old 02-03-2004, 07:15 PM
Overtime's Avatar
Overtime Overtime is offline
Send a message via AIM to Overtime
Question Requesting advice on engine replacment
I just bought 1995 RS with a siezed engine (cheap) and I was hoping I could get some advice on what I can or should replace it with. I have an avenue for purchasing wrecked cars, so based on what I learn, I may have a nice working car for not too much money, but a good bit of work (hey, at least the labor is free!). How new an engine could I put in here? Or should I get an older one to build it up right? I plan on doing a fair number of mods, but Mitsubishi engines are my weak point at the moment. My primary experience has been on Ford and GM.
Old 02-03-2004, 07:36 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Requesting advice on engine replacment
Well here's the skinny:
There is no cost effective way to put a turbo engine (4G63) in an RS. It is ruled out as an option. You can either get another stock 420A or build up your own for use with a turbo kit. To my knowledge, you can get 95 all the way up to 99 RS/GS motors in there no problem (i dont think there were any changes over the years to prevent 99 in a 95)
Old 02-03-2004, 07:48 PM
Overtime's Avatar
Re: Re: Requesting advice on engine replacment
Thanks for the info JoeWagon. I take it then, people prefer a 4G63 engine, or is it just that it is already turbo? Is the problem height, motor mount placement or is it just size? If I could unbolt parts from a wrecked one, would I be able to work around it? Sorry, All I have is what is in front of me right now (420A?).
Old 02-03-2004, 07:50 PM
Overtime's Avatar
After all....
With the right tools, everything is a direct bolt-on.
Old 02-03-2004, 11:02 PM
JoeWagon's Avatar
Banned
People prefer the 4G63 because it comes ALMOST ready to bolt on most turbos for enormous power gain. With the non turbo motor, 420A, you have to buy a kit, which isn't cheap.
Also, 4G63 is built for turbo pretty much, which means it can handle more power on stock internals (400ish)whp compared to less on the 420A.
To put a 4G63 into a non turbo 2g, you need to swap the entire front clip, axles, transmission, wiring harness, etc.. it's been done but I wouldn't recommend trying. Costs too much if nothing else.
Old 02-04-2004, 04:00 AM
kjewer1 kjewer1 is offline
AF - Advisor
When thinking of putting a 4g63 in a NT, to sayings come to mind
Reinventing the wheel.
Shovelling shit against the tide.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-04-2004, 07:27 AM
Overtime's Avatar
OK, so if I want to build an Eclipse, I should just swap out the motor on the one I have and sell it. Then I should buy what? What cars come with this motor?
Old 02-04-2004, 10:45 AM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Get a gs-t or GSX. If you're gonna "build" it, for racing or whatever. I would suggest the GSX. Since it's awd. But both come with the same engine (4g63)
V8's are like tampons, every pussy needs one!
Old 02-04-2004, 12:53 PM
Overtime's Avatar
My plans are for a quick, hot looking car. I don't really have plans for racing, but I do want it to be fast
