Old 02-03-2004, 06:30 PM
blade34609's Avatar
blade34609 blade34609 is offline
Which tranny removal method is better?
Hi,
I am going to remove the 4 speed tranny in my hatch soon.
I was looking at it today and thought instead of having to jack the car way up maybe I could just lift the tranny out with 2 people.
First I take the starter out, axles and everythign are already out.
battery stand and everything is removed already. shift linkage is also already moved. I noticed if I let it drop I will have to remove the radius rod. How hard is it to remove the rod?
But anyways, if I was to have someone support the tranny (without a hoist) and unbolt the tranny to block bolts while having blocks under the block to support it.
First I remove the rear mount then the front, then the side and with to people we should be able to lift it out right?
Or is it better to just jack the car way the hell up and remove the rod and let it drop down?
Thanks
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 02-03-2004, 07:39 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: Which tranny removal method is better?
When I did my swap I had to drop my DX tranny out of the bottom because I couldn't get the linage off. Just take off the mounts attaching to the tranny (there are 3 of them) and than the engine/tranny will hang down, than just pull it off from there and slip it out the bottom.
Old 02-03-2004, 08:09 PM
blade34609's Avatar
so it would just fall out, would u still recommend i block up the block?
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 02-03-2004, 08:40 PM
91zc 91zc is offline
Let the engine and trans hang down at an angle with a hoist. Remove the trans and then either support the block with the hoist or use some wood or a jack to hold the engine block while the trans is off.
91 civic 4dr
b16a
14.8@94
Old 02-04-2004, 12:09 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
and u dont hafta take off the radius rod. i never did
Old 02-05-2004, 12:15 AM
lilol89crx lilol89crx is offline
just gotta slip the tranny around the radius rod. my tranny always hits it when i pull it out from the bottom. never really got in the way though.
