Old 02-03-2004, 06:46 PM
rchldev rchldev is offline
Exclamation 95 blazer
I recently bought a 95 blazer that has no owners manuel can you
tell me how to find where the rear wiper fluid goes looked under the
hood and in the tailgate!!
Old 02-04-2004, 01:36 AM
blazer 1205 blazer 1205 is offline
Re: 95 blazer
The fluid for the rear wiper comes from the same resevoir, that you use for the front wipers... I had the same problem... if you remove the air box, and down under the resevior, thier are two fluid pumps... the higher one is for the front,and the lower one is for the rear... Check the fuse, if not change or test the moter for the pump... check your connections... also if the fluid is lower then the top pump... you wont get any fluid to the front... the motor was a little tricky to remove but not too much of an issue... have fun...
