Old 02-03-2004, 03:47 PM
noyorol noyorol is offline
Send a message via AIM to noyorol
Angry I really hate my DSM...Need some Help
It seems everytime I turn around my car is messing up.Why is it when a DSm hits 100k everything wants to break down.
My problem is now oil pressure gauge is broke and my car idles funny.the idle lopes from 1500 to 2000 rpms.It doesnt do it as bad now since I took the dump tube off but it still bothers me.Any advice?Thanks in advance
Old 02-03-2004, 04:08 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: I really hate my DSM...Need some Help
did you hack the dump tube, or are you venting your BOV into the atmosphere? if you are venting it will give you problems.
Old 02-03-2004, 04:18 PM
No when I was not venting it did it worse.Now that I am it has gotten some what better but did not cure it.So I am thinking its a boost leak somewhere.
Old 02-03-2004, 04:36 PM
what mods do you have on the car?
Old 02-03-2004, 05:05 PM
Its all stock.The motor is rebuilt but other then that its all stock.
Old 02-03-2004, 05:16 PM
Re: Re: I really hate my DSM...Need some Help
you are probably right on about the boost leak. check around the BOV and make sure it is secure, leaks usualy happen here. also, you may want to look into getting an aftermarket BOV. a cheap one is a 1st generation BOV. it is metal [stock 2g is plastic] and you can get them on ebay pretty cheap, and they mount exactly the same. if you are thinking about going further with tuning, just drop a new thread. i'm not going to go into the upgrades you can get into now, but if you want me to i can.
Old 02-03-2004, 08:12 PM
could it be a thermostat problem or someting like that.and how often does the oil pressure gauge brake.well i mean you hear about breaking
Old 02-03-2004, 08:34 PM
If I put a 14b on my car all I need is the 16g install kit?And if I rebuild a 14b can i use 16g internals
Old 02-03-2004, 08:57 PM
urmystlkal urmystlkal is offline
Send a message via AIM to urmystlkal Send a message via MSN to urmystlkal Send a message via Yahoo to urmystlkal
Re: Re: Re: I really hate my DSM...Need some Help
He would need a flange for it to connect...
Old 02-04-2004, 11:59 AM
so will the 16g internals fir in a 14b
Old 02-04-2004, 05:57 PM
kjewer1 kjewer1 is offline
AF - Advisor
Yes, if you get the compressor housing machined ("profiled") for the bigger 16g wheel.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
