Old 02-03-2004, 04:41 PM
pasha's Avatar
pasha pasha is offline
sohc replacements for the 92si motor
obviously the 92-95 sohc vtec motors, from si or ex, will work. but wha about the newer model sohc vtec mototors 96+, will they work with the original tranny. will the wirining and computer work with the newer stuff?
or is it possible to mix and match things?
Need webdesign? I can help ==> 2design.da.ru
Old 02-06-2004, 11:45 PM
H.tech H.tech is offline
Send a message via MSN to H.tech
Re: sohc replacements for the 92si motor
no the wireing will be different you will have to replace your computer with an ODB 2 computer instead of your ODB 1 computer .. Your tranny should match up perfectly and the motor should drop right into your car but you should stick with the 92 to 95 year motor because they are faster and i think they are better for tuning
Old 02-07-2004, 01:42 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
I believe that the D16Y8 has a better flowing IM than the D16Z6. You can use your original ECU, you just have to get a OBD2 -> OBD1 conversion harness. Tranny will also work with it.
Empty Pockets Racing Member #1
Old 02-07-2004, 12:39 PM
pasha's Avatar
thanks guys
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
