Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-03-2004, 02:14 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
What would i have to do, to get a prelude (4th gen) into 14's?
anyone!!!
any mods
but try to be as low costing as possible....
wwhat would be the best /quickest way to go..
nitrous?, N/A, Turbo?, Supercharger??????????
Old 02-05-2004, 05:31 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
Re: What would i have to do, to get a prelude (4th gen) into 14's?
in the 14's huh?
best I can say is get a turbo and run at about 6-8 PSI on stock internals... still gonna cost you about $2000-$3000 depending on the package you get.. I suggest you get one(larger turbo) that goes above what you'd need.. in case you want to upgrade later.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 02-05-2004, 05:35 PM
to run higher PSI you'll need to upgrade your internals.. pistons, rods, crank, cylinder walls will need to be sleeved.... and so forth... but the turbo (5-8 PSI) should add about 50-70 HP depending on fuel used, and tuning. and should push you into the 14's which is'nt that hard... It's when you get into the 10's and 9's that it get's really tough, and VERY costly..
You can also strip out some excess weight in the car... that can shave off a 1/2 second depending on how ravenous you get on the interior..
