Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 02-03-2004, 02:12 PM
belmont3 belmont3 is offline
Is this possible? Cracked Block)
98 (115k miles) goes in for an emissions test (they run it on a dolly). After test, it is driven and is bucking. Computer scan says engine misfire. Long and short is the block got cracked, as apparently the diaphragm on the fuel rail malfunctioned, causing the back cylinders to fill with gas. Is this possible? Seems an odd design flaw? Thx.
Old 02-04-2004, 09:25 PM
mr.belvedere's Avatar
mr.belvedere mr.belvedere is offline
Talking
I doubt that the block would crack due to a pressure regulator failure, however, if the cylinders were filled with fuel, there could be some damage to the piston rings, or connecting rods. Liquid fuel cannot be compressed, so when the piston comes up, something has to give,and it's usually the rings or the rods. Im curious as to who said the block was cracked. Did you have a technician look at it? I've been a tech for 14 yrs. and have never seen a block crack from a "hydro-locked" cylinder.
