Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-03-2004, 09:27 AM
luv2bowl luv2bowl is offline
Name of part
I have a 96 Jimmy. When I put it in 4 wheel, the front wheels don't turn as they are supposed to. I do not know what the name of the part that is bad is. I was told it is a common problem and a pretty easy self fix. It is located near the transfer case if I remember correctly. I know this might not help, but if anyone knows the name of this part and maybe even a part numer, it would be greatly appreciated.
Old 02-03-2004, 05:23 PM
XtremeXP's Avatar
XtremeXP XtremeXP is offline
Re: Name of part
vacuum switch maybe?
Old 03-08-2005, 10:12 PM
96jimmy4wd 96jimmy4wd is offline
located in the rh side bottom of the front axle housing is a switch and a cable. remove the cable and be sure it moves freely in its sleeve also check the diaphram on the other end (under the battery tray) I had the same problem
Old 03-11-2005, 05:55 PM
Blue99JimmyEnvoy Blue99JimmyEnvoy is offline
Transfer case motor? It mounts directly to the transfer case, and can cause 4wd not to engage. Usually an easy fix.
