Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 02-03-2004, 03:30 AM
christina1958 christina1958 is offline
Question oil pressure problems
the gauge on my lincoln ever so often goes up and down. causing the alarm to sound. if I bang on the dash the gauge returns to normal. any ideas out there.
Old 02-03-2004, 03:54 AM
matada's Avatar
matada matada is offline
Send a message via AIM to matada
Re: oil pressure problems
Could possibly be the sending unit to the gauge, a faulty oil pump, or a faulty gauge itself.
First thing you should check is if the oil pressure warning light is activated. If so, Check the oil level before you drive the vehicle, then take it to a reputable mechanic. Actually, with this type of problem, it is always better safe than sorry, so the mechanic is the way to go.
Hope that helps a little, and good luck.
Count em.....
matada19: she die?
OoToksinoO: no, unfortunately
matada19: damn
OoToksinoO: cant win em all man
matada19: can i sig that?
Old 04-21-2004, 07:28 PM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
THE FIRST THING THAT I WOULD CHECK IS THE SENDING UNIT MAKE SURE YOU HAVE GOOD OIL LEVEL
BUT THE LINCOLN ALL HAVE A BAD G AGE MINE DOES
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
Old 04-22-2004, 12:33 AM
Towncar's Avatar
Towncar Towncar is offline
Have a look at This thread on another board, there's some good clues there.
-Steven
1996 Town Car, Cartier
Old 04-25-2004, 08:51 PM
nowers nowers is offline
My mom's 91 continental does exactly the same. A couple years ago she took it to a gas station in AZ and they swapped the engine with less than 60K miles at about $4400.
Its not the sender. Its not the pump. Its not the engine. Its a fault in the computer which runs the instrument panel.
Now if someone could tell us how to disable the damn chime, we could have some peace.
dave
Old 04-26-2004, 08:33 PM
I have a 93 lincoln continental and it does the same thing the only thing that you can do is disable the warning bell for it and that is on driver side under the dash but there is a catch too.
when you take out that bell you take out all of those bells cheek engine, low washer ,low oil and etc.........
I hope that this helps
69" BUICK RIVIERA
1999 OLD ALERO
Old 05-29-2004, 04:37 PM
wckdredhead wckdredhead is offline
I have a 1992 Lincoln Continental I purchased private sale from a salesman at a dealership. My oil guage does the same thing...along with the annoying beeping that goes with it. It does it alot in the summer...and never in the winter. The seller told me he had it on the diagnostics machine a dozen times and it was finally determined it was the computer head. He told me if it got to annoying he could get me one for about 100 bucks, but that it wasn't hurting anything to leave it for the time being.
Just keep an eye on your fluids and check it regularly.
The car came with a 2 inch file of maintainence records so I know it was well cared for.
Hope this helps.
Old 07-27-2004, 06:49 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
My wifes would have an erradic oil level... digital dash... we had it checked out and it is the dash cluster itself that is the problem that might be yours.... does it ever show lines on top and on bottom but not in middle(digi dash)? I have heard that the dash has been a problem.
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 12:08 AM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 08:33 AM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 12:37 AM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
