Old 02-03-2004, 12:28 AM
ranan21 ranan21 is offline
Send a message via AIM to ranan21
floating hood trick?
does any one know how to do this trick? If so what materials are needed? Thanks any help is appreciated
Old 02-03-2004, 09:52 AM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Old 02-03-2004, 12:16 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Magic.
Yup, I have no idea what this floating hood trick is.
Old 02-03-2004, 02:47 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Re: floating hood trick?
The "trick" is simply hydrolic shocks (like the ones on your trunk). They are positioned on hinges inside your trunk, on all 4 corners. So instead of your hood only raising from the rear, it goes up as one whole unit, but only about 8 inches. You will def need hood pins!!!! I repeat GET HOOD PINS! At about 50 mph the hood comes flying off if you don't have them... don't ask how I know this You can get one of those cheap cd's off ebay for like 4 bucks and it will tell you what parts you need and give you blueprints. Or there are kits you can buy. But you're going to pay a lot for them and you can do it cheaper yourself.
V8's are like tampons, every pussy needs one!
Mercedes Benz Hood Star brandonbenz E-Class 0 03-02-2010 07:22 AM
01 Beetle - Hood Won't Unlatch mhalliar Beetle - New/New Beetle Convertible 1 12-17-2009 12:37 PM
1997 Taurus starting trick - will not start until whirring noise stops under the hood Taurus1997 Taurus | Taurus Wagon 117 11-20-2006 01:34 PM
dose any one know how to make your hood look like its Floating cwlewallen '88 - '91 Civic | CRX | Wagon | Shuttlee 17 04-05-2005 07:39 PM
Single Piston Floating Calipers vs 4 Piston Non-Floating Calipers IOIOOI M3 0 02-09-2002 09:30 AM
