Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-03-2004, 12:20 AM
Jszy Jszy is offline
Post turbo install TUNING
I've heard that the toughest part about installing and running a turbo
setup is tuning it to run correctly after its installed. How does someone do the actual 'tuning'? Does the tuning refer to adjusting the fuel system...or does it mean adjusting boost and that sort of thing or both? Help me out here...
Old 02-03-2004, 09:19 AM
tibby01 tibby01 is offline
adjusting fuel so that you are not running to rich or lean. sometimes a little rich is ok. you do this with a wideband o2 sensor. and then maybe adjusting boost and coming up with a good setting for two boost spots.
there are tons of different things you can use. after reading up on the hondata though, id say its prolly the best unless you wanna go the haltech route.
Old 02-03-2004, 02:49 PM
Re: Post turbo install TUNING
How are you able to control the fuel with the o2 sensor? Is it not just a sensor? And why do you want 2 boost spots?
And another question. What if you just have a turbo kit in your car with just an FMU, no electronics to manage it. How would you tune it then??
Old 02-03-2004, 11:06 PM
no, you read the o2 sensor to make sure you arent running to rich or to lean, and then you adjust the amount of fuel that gets dumped into the engine to adjust the a/f ratio.
and you could have 2 boost spots say...one for the road...and one for the track.
Old 02-05-2004, 10:50 PM
n2o_2k's Avatar
n2o_2k n2o_2k is offline
Re: Re: Post turbo install TUNING
How do u tune it?
Old 02-05-2004, 11:14 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: Re: Post turbo install TUNING
get the electronics, get a s-afc its the cheapest way to tune your fuel, for honda the hondata is also a powerful tunnin tool..but tis more $$
1
Shift_BOOST
97 s14
Ford Probe 1992 2,2 turbo ptq Probe 0 04-13-2009 03:30 PM
Turbo install on a non-turbo 300zx Z31 DrSmiley 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 6 12-10-2007 07:54 PM
1995 Honda Civic CX Turbo - Honda Tuning Magazine Automotive News Automotive News Desk 0 07-25-2006 06:10 PM
greddy turbo kit tuning Jackinthebox3181 N2O | Turbo | Superchargers 10 12-28-2004 08:28 PM
