Old 02-02-2004, 10:15 PM
n2o_2k's Avatar
n2o_2k n2o_2k is offline
Question Clutch or transmission fuild ?
How do i do to check the clutch or transmission fuild on my car, i got a 95 eclipse rs.
Thanks for your help
Old 02-02-2004, 10:20 PM
CODE4 CODE4 is offline
Send a message via ICQ to CODE4 Send a message via AIM to CODE4
Re: Clutch or transmission fuild ?
The tranny fluid can be checked by pulling the black rubber plug off of the driver's side of the transaxle. Dip your finger in, it should be right at the bottom of the hole.
The clutch fluid is checked at the clutch master cylinder, between the brake master cylinder and the inner fender well. It should be filled with DOT3 or other brake fluid. If neither are clean then it is time to replace. BTW, the tranny fluid will smell like ass too =]
______________________________________________
1999 Eclipse RS
ET: 16.1 @86.241 | Speedworld Motorplex, Phoenix, AZ
Old 02-02-2004, 11:16 PM
95eclipse-gsx 95eclipse-gsx is offline
how does an ass smell ??? caz i never smelled one before
Old 02-03-2004, 12:00 AM
n2o_2k's Avatar
Re: Re: Clutch or transmission fuild ?
Thanks for your quik reply, do you have any pictures that i can use as a guide?
Old 02-04-2004, 12:09 AM
Re: Re: Re: Clutch or transmission fuild ?
Negative on that, sorry. If you have any questions you can post them here.
1999 Eclipse RS
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
