Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-02-2004, 08:00 PM
arsin21 arsin21 is offline
Send a message via ICQ to arsin21 Send a message via AIM to arsin21 Send a message via Yahoo to arsin21
Question will skyline rear end fit a 240sx?
I would like to know if a skyline rearend would bolt up to a 95 or 97 240sx and if it dose what would i need to do it?
Old 02-02-2004, 08:12 PM
VQuick VQuick is offline
Re: will skyline rear end fit a 240sx?
Are you just talking about the taillights? Actually, there probably aren't any parts that will just bolt on.
It'll take a lot of work to get something from a Skyline's relatively large rear end to fit on the S14's smaller rear end.
“What does ‘kouki’ mean? Are you saying my car is crazy or something?”
Scott-Revs: Motown Muscle
Old 02-03-2004, 05:21 PM
will the s15 silvia rearend work?
Old 02-04-2004, 07:18 PM
I still don't know what you mean by 'rearend.' The entire rear end, or just the tailights?
Then again, there really isn't anything that will just bolt on, even if you're just talking about the headlights. You're talking about doing something that wasn't meant to be done, and it will require some modification.
Old 02-04-2004, 08:21 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
are you talking about the rear of the car or the rear differential, also referred to as the 'rearend'.
Old 02-05-2004, 03:38 PM
-ExCesS-'s Avatar
-ExCesS- -ExCesS- is offline
Send a message via AIM to -ExCesS-
i belive he means the tail-lights
Old 02-05-2004, 03:41 PM
musicsurfman musicsurfman is offline
Send a message via AIM to musicsurfman Send a message via MSN to musicsurfman
If You Mean The Rear K-frame Then Yes They Do. S13, Z32, R32 Are The Same; S14, R33 Same; S15, R34 Same..... You Can Also Cross Over Between And Put A S14 Frame On The S13, Etc With A Bit Of Modification.
Old 02-05-2004, 03:54 PM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
and if he means rearend as in differential they will all fit.
S13, S14, S15
R32,R33, R34
Z31, Z32, Z33???
240z, 260z, 280zx
Q45, J30, M30
they all use the R200 nissan rear differential.
Old 02-05-2004, 04:06 PM
DeSantes DeSantes is offline
I think it's pretty much a consensus, if you have the cash then anything is possible. In regards to the cosmetic changes you're after, that will require a bit of custom work from an autobody shop. There are no bolt on type kits available in the US to my knowledge.
Follow the progress of my S14.5 at http://www.240sx.net!
Pioneering a new 240SX Community. Sign-up and help us grow.
Old 02-06-2004, 08:41 PM
thanks a lot for the info SR20detpower
Old 02-06-2004, 09:34 PM
so i guess he was talking about the diff.
Old 02-10-2004, 12:26 AM
13team 13team is offline
does any one know if a 300zx 1991 rear sub frame fit in a 240sx? like what the control arms mount on to and if the control arms are the same
Old 02-10-2004, 06:02 AM
Banned
I've heard about people using the rear spindles and strut assemblies when converting to 300zx brakes in the rear. The rear end is probably wider, and there not much to gain from the swap, spend ur money on beefing up your own subframe, aluminum subframe spacers, differential, struts/springs, brakes, control arms, and some bushings
Old 02-10-2004, 07:16 AM
The Rear K-frame (subframe) Can Be Swapped Like I Said Which Means Diff And Axels Do Too.
Ohh Btw Your Welcome For The Help Even Though You Only Acknowledged Sr20det.
Old 02-10-2004, 11:31 AM
i need to know because i have a rust problem on the 240sx subframe but and the 300zx is solid
