Old 02-02-2004, 07:49 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
25 psi???
First i blew my 20G a few weeks ago so i put stock turbo back on. Now the problem is that my boost gauge is reading 25PSI (no i have never owned a boost controler of any sort) Another thing is its holding this boost over 6000RPM. I did not think the turbo could even do this? Does any one know how or why this is happening.
Thanks for the help
Old 02-03-2004, 02:28 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: 25 psi???
you were running a 20g with NO boost controler???
Old 02-03-2004, 07:50 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
classic
-Agim
Old 02-04-2004, 04:02 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 25 psi???
The WG must be stuck closed. It has nothing to do with the lack of an MBC. Remeber that running no MBC will give you spring pressure (typically 10 psi or so on mistu internally gated turbos, 14 on most externals) as long as the vac line is at elast hooked up...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
