Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 02-02-2004, 06:20 PM
93Civicgurl 93Civicgurl is offline
Send a message via AIM to 93Civicgurl Send a message via Yahoo to 93Civicgurl
For those with trans problems
Hey I had been having problems with my transmission on my 2000 V8. We finally got a chance to look it over and discovered that the plug wires needed to be replaced. Two of them were not staying snapped onto the plugs causing a short.
My trans kept slipping in and out of gears. Hope this may help some of you... Now I need some help.
I can't get my heater to work. The air conditioner works well even when the heater should be on... Any suggestions on how to fix this??
Old 02-23-2004, 01:21 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: For those with trans problems
the ac is supposed to be on if the heaters on defrost to remove moisture. what wrong with the heater? no heat?? won't change position? check your fuses first. could be a bad switch, blend door actuator, clogged heater core, bad thermostat, bad wires. lots of possibilities here. give me some more info and i'll make an educated guess!!!
Old 02-23-2004, 11:33 AM
We removed the thermostat to replace it and discovered that the thermostat was broke in half. I replaced it and now my heater works really well...
Thanks for the help though...
My car now has a salvaged title...
