| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
Rover 620si airbag srs light
Hi m8's been having loads of problems with electrics l8ly had to replace some fuses for the headlights and i have gone through all the fuses checking them 1 by 1.
But now i have got my srs light on all the time, i have read that this can be caused by power to the srs system being dissconnected and that there is a way to reset it by using a jumper and doing somthing with the ignition. Question is does anyone have the details of how to do this please? Any help most thankfully received. |
#2 | |
Re: Rover 620si airbag srs light
I know how to reset the ecu on a coupe so it might work on the 600's. You basically turn the key to pos 2 and fully push the accelerator (or gas pedal I think you call it in America?) and let it off fully. Do this 5 times within 30 seconds and then tuurn the engine on.
On my old coupe it fixed the dodgy idle speed so you never know, it may fix the srs light. I know if you pull the fuse on the abs the light comes on as a warning, guess it's the same with srs. Not knocked a wire in the wheel have you?
Pete ![]()
#3 | |
thanks for the reply m8 i tried what you sugested but it didn't work.
but thanks for the sugestion must be another way to do it |
#4 | |
I'll ask on the rover forums I subscribe to.
Pete ![]()
#5 | |
Its ok now m8 ive got it sorted a very kind member on another forum has gave me the required info to reset it.
Thanks for all your help m8 its very kind of you |
#6 | |
glad to hear all is ok, I was going to point you to this thread from another forum, it may help you in the future anyway:
http://www.rovertech.net/forum/viewt...746&highlight= Cheers,
Pete ![]()
#7 | |
What was the solution found please - I have the same problem on a 620ti
Thanks |
#8 | ||
hope this helps m8. |
#9 | |
Fantastic - thanks for your time - it worked :-)
#10 | |
No problem m8 glad i could help
