Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-02-2004, 02:00 PM
mjohn mjohn is offline
Cruise stopped working
1993 GMC Jimmy 4dr...
The cruise control stopped working...
Where are the fuses located...
Think it is a fuse?
Old 03-01-2004, 08:44 PM
CQB-241 CQB-241 is offline
Send a message via AIM to CQB-241 Send a message via MSN to CQB-241 Send a message via Yahoo to CQB-241
Re: Cruise stopped working
Im not for sure in your case-- But I know in mine the wire leading from the steering wheel column-- into the handle where the cruise button is-- some how got cut. Still trying to figure that one out. But if you want to check the fuses-- they are located below the dashboard-- drivers side-- all the way up against the paneling-- it says "Fuses'. There is a screw you have to remove-- then pull them out. Do that while I figure how to re-wire my cruise wire
Old 03-02-2004, 01:42 AM
amac209 amac209 is offline
Send a message via MSN to amac209
the first thing to check with an electrical problem is the fuses. check all your vacuum lines. check the switch at the brake pedal.
Old 09-08-2004, 12:02 PM
CJ1389 CJ1389 is offline
I am having the same problem, everything else on that arm works (wipers etc.) works. What does the switch on the brake pedal look like?
Old 09-08-2004, 03:25 PM
wilfie27 wilfie27 is offline
Look on the side of your throttle body to see if there is a small cable just hanging there. I initally repaired mine with a bread tie but replaced it later with the proper clip, the bread tie looked stronger though.
