Old 02-02-2004, 12:29 PM
sLADe781 sLADe781 is offline
Oil Change
There's this 3000GT that hasn't gotten an oil change in over a year (about 14 months), but it hasn't passed the 3,000 mile bench mark since the oil was changed (about 300 miles left). I know you're suppose to get an oil change every 3K miles or 3 months, so how bad is it that the car hasn't received an oil change? For the most part, the car is parked in the garage and taken out once a week to keep it "fresh." I'm looking into buying it but if the lack of oil change has severely damaged it then I would not want to buy it. Thanks again guys.
Old 02-02-2004, 12:38 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
I would have the oil changed as soon as posible, oil breaks down over time and doesnt do as good of a job lubricating the engine. If its synthetic oil you dont have much to worry about, if its regular the car is most likely fine, but the oil needs to be changed as soon as it can.
Old 02-02-2004, 12:45 PM
Re: Oil Change
How do you know if it's synthetic oil or regular oil? The car was taken into the shop and the oil was changed there. Thanks for the help talskinyguy.
Old 02-02-2004, 10:56 PM
If he doesnt know what was put in it then its regualar oil.
Old 02-02-2004, 11:17 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
An oil change is twenty bucks.
A damaged engine is several thousand dollars.
You get the picture
I get mine changed every 2k miles. But I'm obsessive like that.
Old 02-03-2004, 09:48 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
The 3 month and 3K oil change is a moneymaker for anyone associated to the oil industry. You will do no harm in changing your oil that often, but the reality is that the car manufacturers do not require that it be changed that often (take a look at the recommendations in the manuals). Unless you drive your car exceedingly hard, the oil will not break down that fast.
Given that, you don’t want to leave the same unused oil in an engine for a year. You’ll certainly want to get it changed. If you have any question as to the type of oil you probably should go with a synthetic. It doesn’t hurt the engine to go from regular to the synthetic stuff, but you do not want to go from synthetic back to regular. The synthetic expands your seals while the regular will shrink them back and potentially cause leaks.
Resistance Is Futile (If < 1ohm)
Old 02-03-2004, 11:08 AM
AcesHigh's Avatar
Prelude Guy
Learning how to do it yourself is also really helpful. It takes only a few minutes, and costs the price of the bottle of oil. It's too cold out right now to do it, but it's quite painless when its warm out.
Old 02-03-2004, 10:48 PM
Re: Oil Change
I currently change mine every 5-6 thousand, this summer im switching to AMS Oil, recommended oil change intervals, 20-25k miles with a filter change 1/2 way.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
