Go Back   Automotive Forums Car Chat > Toyota > IS200/IS300/IS350/Altezza
Old 02-02-2004, 12:10 PM
carina_rwd carina_rwd is offline
altezza wiring diagram (3S-GE Beams)
I´m looking for wiring diagram to rs200 altezza, 3S-GE beams with manual transmission.
Any ideas where to get one?
kari
Old 02-02-2004, 08:32 PM
matada's Avatar
matada matada is offline
Send a message via AIM to matada
Re: altezza wiring diagram (3S-GE Beams)
do you need the entire diagram? I have bits and pieces here, so if you are looking for something detailed I can probably help out (like the ecu plug description etc.)
Count em.....
matada19: she die?
OoToksinoO: no, unfortunately
matada19: damn
OoToksinoO: cant win em all man
matada19: can i sig that?
Old 02-03-2004, 02:09 PM
Re: Re: altezza wiring diagram (3S-GE Beams)
everything helps I think. I´m putting that kinda engine into a old carina, I have altezza frontcut and all wires and boxes are there. But I think there are lots of extra and unwanted stuff also. So espesially all wires etc. which are directly connected to engine management are most needed.
thanks
kari
Old 02-15-2004, 03:42 PM
is this forum dead or something
please, someone! I need help to get that wiring diagram. Beams 3S-GE sits nicely in old skool carina and even that 6-speed trans fit perfectly, but it would be nice to drive it also.
kari
Old 02-21-2004, 02:31 PM
I´ve sorted out quite much of those wires, but I really need ECU pins/connectors "chart" any ideas were to get some help?
Old 03-02-2004, 11:45 AM
chengkhang chengkhang is offline
Send a message via AIM to chengkhang Send a message via MSN to chengkhang Send a message via Yahoo to chengkhang
yes is this thread dead?????
i am also looking for altezza wiring diagram (3S-GE dual Beams vvti)
no luck yet.....
i am putting it into my 93 mr2...its in it already... i just need too figure out the wiring... hopfully i finish it this year.....
help any one....
Old 03-03-2004, 03:13 PM
toysport(.com) in usa can seek those wirings and translate those to english, it will take about 2-3 weeks and costs $100.
it might be the only way to get our beams run again
Old 06-29-2004, 05:21 PM
Silo Silo is offline
chengkhang, you have installed the black top Altezza 3S-GE in your 93 MR2? Do the engine mounts match or did you have to make custom ones?
Did you get the wiring diagram yet?
Old 08-01-2004, 08:49 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
How Much Different Is The Altezza Wiring Loom? I'm Looking At Putting One In My Mr2 But I'm Wondering If I Can Use The Same Computer For My 3sgte Until I Do The Swap? I Know The Program Would Be Different But Can I Do It Phisically?
Old 11-17-2004, 01:05 AM
yes i have it installed... the altezza 3sge is the same block as the mr2 turbo soo it bolted up prefect with the tranny, remeber 3 of 4 mounts are mounted on the tranny, oh yeah it bolts on to the stock mr2 tranny to,... so yeap it fits prefect,.. no custom if you did it like how i did it,... which i am trying to do the least not need custom work,....
oh took pictures,... i gota see if i still have them,.....
Old 11-17-2004, 01:11 AM
theres a whole lot of different thats why im looking for help,. on harness work and looking for diagrams,..... i dont think you would want to use the 3sgte ecu total different,.... altezza 3sge has dual-vvti,...... you can modify the motor but whats the point of getting that motor for if you dont want vvti,... unless you just want the aluminum block,...??????? thats coool tooo
Old 11-17-2004, 12:44 PM
TRD2000's Avatar
i didn't realise it had an alloy block! I want to turbo it so perhaps i should look at using my iron block and the altezza head? decided to use a motec ecu.
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
Old 11-18-2004, 12:51 AM
what would be cool if you can re-sleeve with titaium sleeves, the alloy block like hondas, now that would be tight,.... and then turbo,.....
Old 11-18-2004, 12:37 PM
TRD2000's Avatar
yeah... that would definately be cool. doesn't honda use a an CRM compound for their sleeves as standard? well on the NSX.
do you think the 4th gen BEAMS head will bolt to an older gen block?
Old 11-20-2004, 03:43 PM
ummm i donw know i havent taken the head my beams yet, but i would think so,.. lets just hope,...... its is still the 3s block
