Old 02-02-2004, 11:22 AM
lsysmac lsysmac is offline
97 Tahoe, vibration at 65 mph
We have a 97 Tahoe that has quite a bad vibration at 65 mph. We had a front end alignment about two months ago. We got new tires about a month ago. This vibration started as a once in a while type thing. Now it is regular. It also does the vibration thing when decelerating - generally from about 45 or 50mph.
Old 02-06-2004, 09:55 PM
cody7 cody7 is offline
Re: 97 Tahoe, vibration at 65 mph
if there is no new noises with it my guess would be tire balance (they tend to slip on the rim at first with the bead lube) but what shape are the u-joints in?
Old 02-07-2004, 09:44 AM
Tony Viv Tony Viv is offline
Send a message via AIM to Tony Viv
check ujoints, I just did em same thing happening to me
Tony V
98 Tahoe Sport z71
03 Wrangler
lifted
Old 02-29-2004, 01:22 PM
toughtahoe toughtahoe is offline
Unhappy 1997 - Vibration at low speed.
I have a similar problem w/ my 1997 tahoe has a shimmy in steering at low speed. I had it checked and they (Garrage) had to replace the Pit arm and Idler arm but the problem has not completely fixed but with the new parts itsn't as bad as it was. I know the vehicle requires new set of tires and i hope this will solve this problem.
Old 03-04-2004, 10:39 AM
GTRhino24's Avatar
GTRhino24 GTRhino24 is offline
I work at a tire shop and we get this sort of thing alllll the time. The U-Joints are a good starting point because I replaced mine when getting an odd vibration at speed and one of the clips were gone and a cap was coming off. Another suggestion is that you take a feel of your tires. A 97 with old shocks could cause chopping out on your tires. If you notice a rough texture to the overall tread of your tires than that can easily be the source of the vibration.
Ryan
96 Tahoe 2Dr 4x4
315/75/16 BFG ATs (Yes, they will fit.)
2.5" Skyjacker Suspension Lift
2001 Tahoe LT Rims
Old 03-05-2004, 09:03 PM
Rick246 Rick246 is offline
I had the same problem with my 99, turned out the shocks were shot at 65,000 miles.
