Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-01-2004, 10:41 PM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
white smoke
i have a used t3 turbo installed and when i drive the car a little hard i let it idle for a while, and then shut it down, but when i start the car back up there is a lot of white smoke comming out of the muffler. eventually it will stop smoking until i drive it hard again. did i blow my motor or is the seals in the turbo just bad? if its just the turbo can i still use the turbo for a little?
Old 02-02-2004, 05:50 AM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
hmmm....
Black Smoke=burning oil
Blue Smoke=Burning coolant
White smoke=Running rich? Lean? or is this the coolant one?
Eh tried to help
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 02-02-2004, 03:16 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: white smoke
Black smoke = running rich
White smoke = burning coolant
Grey/bluish = burning oil
Are you loosing any coolant? Also th last time you changed your oil did it look funny, milky, or foamy? If it is doing this in the mourning after the car has been sitting for a while then it is normal, unless it is doing it after the car is up to operating temp.
Old 02-02-2004, 05:19 PM
PunkAlex's Avatar
Re: Re: white smoke
HAH HAH holy shit i was way fucking off!
Old 02-03-2004, 10:10 PM
Poison Rice Poison Rice is offline
Send a message via AIM to Poison Rice
Re: white smoke
I see on TV when a race car F*cks a turbo, it has a BIG plume of white very white smoke......and Lots of it too.....
Burnout: Ultimate show of power
Drifting!
Gopeds!
Old 02-03-2004, 11:17 PM
IntegraB18LS's Avatar
IntegraB18LS IntegraB18LS is offline
does it smell like gas oil or coolent? white smoke is usally leaking head gasket but alot of times it will smoke white with just a little bit of oil
[url=http://www.automotiveforums.com/vbulletin/showthread.php?
1995 Honda Civic EX
-Integra B18B1 LS engine
-Turbocharged
-Rear disk conversion
-Many mods
Cheak out my civic (cardomain)
Easly got 10k into this car with everything and it still looks like a POS
Old 02-04-2004, 01:10 AM
it doesn't smell like any of those. this smell is weird, i never smelled anything like it. its hard to explain what it smells like. but it doens't do it anymore, it probably will when i drive it hard again. my friend siad that when i floored it there was a big puff of white smoke, and then black smoke. it didnt keep smoking after i shut it down and turned it back on. so i have no idea now what it can be now.
Old 02-04-2004, 04:11 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
Re: white smoke
run your car for a while, then check the seals on the turbo, and on the head.. you can also crack the intake manifold off the engine and check for oil on the inside of the intake. I would say the white smoke is from burning oil that is either in your intake, and finding it's way to the cylinders, or you have oil in your exhaust that is heating up and burning in your exhaust..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 02-05-2004, 05:54 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Well, if it was just a quick puff of white smoke I would suspect a small amount of oil being burnt. If you get a long duration of white smoke then you have coolant getting into the engine usually via a blown head gasket or sometimes a cracked block or head. The black smoke was probably just carbon deposits, nothing to worry about.
Old 02-06-2004, 12:44 PM
integra111 integra111 is offline
Send a message via AIM to integra111
MY car shoots out white smoke also. Big puffs when 1st turn on. I dont think the turbo is causing. I have a leaking head gasket, check out your head gasket i think thats my problem, i also have 210k miles
Old 05-30-2004, 11:42 PM
brianssteg brianssteg is offline
Re: white smoke
when i hit the gas on my car take it to high rpm's then let off the gas or shift gears a cloud of smoke comes out of my exhaust and then sometimes it seams like its coming through my floor board. what could this be?
