Old 02-01-2004, 08:01 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Need to replace CV joint?
On my pasenger side the black boot it ripped open, oil on the inside of my rim/on the boot, and when I turn you hear it clicking. Does that mean I need to replace my CV joint? How much does that cost and is it hard?
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 02-01-2004, 08:25 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: Need to replace CV joint?
If it clicks the joint is already destroyed. You need to just replace that whole axle. You can get them for like $50 at auto parts stores when you bring the old axle back.
Old 02-01-2004, 10:17 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Yeah, the joint is destroyed, and it is considerably easier to replace the axle, and not too much more expensive.
Old 02-01-2004, 10:24 PM
vesper's Avatar
vesper vesper is offline
Send a message via AIM to vesper
mine clicks too. has been for a while. how long does it take for them to finally give out. my luck i'll be on the highway stranded.
Old 02-02-2004, 01:00 AM
BullShifter's Avatar
Re: Re: Need to replace CV joint?
Axles aren't hard to replace. Removing the axle nut can be a little tricky without air tools.
Only time will tell Vesper, if you know it's bad then I would replace it.
Old 02-02-2004, 10:06 AM
darolh darolh is offline
They'll last a long time before they finally fail. USUALLY you'll go crazy from the noise first.
91 Civic Si, 04 SVT FOcus, 67 CT90, 91 CT70, 86 Samurai, 89 F250, 72 Witton, 85 Yanmar, 98 Kioti......too many friggin' machines.
Old 02-02-2004, 05:04 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
one tip: use a pickle fork to get the lower controll arm off not a 2 jaw puller its so much easier
once you do it, the 2nd and 3rd times are cake!
2002 Acura TL Type S
1991 Honda Crx Si
Old 02-02-2004, 05:47 PM
vesper's Avatar
the 2 jaw puller doesnt work i have tryed it. the fork works well. the first time i had to beat the hell out of it but it finally worked. now they pop out like nothing.
Old 02-02-2004, 08:09 PM
The best way to do it is not even touch the ball joints, just unbolt the LCA from the subframe...
http://www.fourthgenhatch.com/axle.html
Old 02-02-2004, 08:21 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
hey i just replaced my axles in January. Today, I have my wheel turned as far as it would go and I head a couple clicks from the suspension, what could it be? i only turned a bit so i didn't get to listen to it
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
