Old 02-01-2004, 07:48 PM
JOnEB4EvR JOnEB4EvR is offline
Send a message via Yahoo to JOnEB4EvR
Quick question on wiring under hood...
Underneath where you put water/anti-freeze, there's this little electric connection that I don't know what is for. My car is a 2.0 DOHC Turbo just if you needed to know the way it looks. But at that connection the wires are cut and only the plug is there with two wires on the other ends. Anyone know what its for?
2003 Ford Focus ZTS
Old 02-01-2004, 10:03 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
does your water temp gauge work? i'm not positive on where its at on the 1g but if your temp gauge doesnt work i'll bet its that! either that or do the 1st gen cars have a low coolant warning light, that could be a trigger for that also...
Old 02-02-2004, 07:52 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Quick question on wiring under hood...
Yes, if you mean the wire comes off the coolant reservoir, then that is the low level light. Hard to figure this stuff out over the internet though, there are several other wires in that area. If you can get a pic that would help.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-02-2004, 09:03 AM
Um, well its actually on the pipe where the coolant goes, not near the reservoir. My temp gauge works fine... but my car was overheating a couple days ago. Whenever I just sat there idling, it got warm, but when I would driver it would cool down. Could it be some kind of power that triggers the thermostat?
2003 Ford Focus ZTS
Old 02-02-2004, 09:12 AM
rysbrnr's Avatar
rysbrnr rysbrnr is offline
If you're describing where I'm thinking about, the wire harness that has 2 wires is the "low coolant" sensor IF it goes into the coolant resevoir tank. The one with 4 wires in that area is the cooling fan power (2 wires) and the a water temp sensor (2 wires).
01 Audi S4 - "stage 2" mods 13.5@101 on snow tires & 91 oct.
01 Integra Type R - mostly stock w/JDM front conversion
94 Acura Legend - stock
92 Eagle Talon Tsi AWD -
TD05/06 20g turbo, 3" downpipe,Apex-i N1, K&N filter, ported 2g manifold, tubular o2 housing w/Tial 35mm W/G, 2.25" IC piping, Apex-i Intercooler, Blitz BOV, 650cc inj, 255;ph pump, Aeromotive AFPR, Aeroquip -6AN, Apex-i S-AFC, AVC-R, + more
Old 02-02-2004, 04:55 PM
AF - Advisor
If the fan switch was disconnected it could cause overheating while sitting there. Do the fans come on? And I though the fan switch was on the radiator on 1Gs though...
Kevin Jewer
Old 02-03-2004, 07:03 AM
yea, rysbrnr, it was the low coolant sensor... i guess whoever had the car before me cut the wires, maybe the light was always on, and they didn't like it... i need to get that taken care of.
and i know the fan that's in front of the exhaust manifold wasn't working. i looked into it and i noticed that at the connection, where that little rectangular cage thing is... there's a soldered connection... well it came off... so im gonna have to solder it back on...
plus there's a hairline crack on the top of the radiator... i put some jb weld, think that's good enough? im gonna take it for a driver tomorrow, since i gotta go to work now, and afterwards i got to go to church... we'll see... thanks all.
2003 Ford Focus ZTS
