Old 02-01-2004, 01:47 PM
chast9693 chast9693 is offline
Radio code
I have a 1995 Honda Accord with a sick radio. I need the code for the radio. The following information is available: CQ-LH1410Z SN: 93c830983.
I bought this car used for my daughter.
Old 02-01-2004, 03:45 PM
BullShifter's Avatar
Sounds like you already removed the radio to gain access to the SN. Now with the radio removed, drive the car over to Honda & get the code for free.
You also might want to check all compartments & under removeable covers(fuse boxes, etc) for a little white sticker containing the SN & radio code. The sticker should be on/in the car if the orginal tech properly PDI'ed the car.
If the radio displays code error you must remove the back-up fuse from main fuse box(underhood) & re-enter correct code.
Nothing against you chast, but one of these mod's needs to put a radio code sticky in every honda/acura forum. Very common question with the same answer.
Welcome to AF
Old 02-01-2004, 04:00 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
what I wanna know is, why do the OEM idiots put these anti-theft stuff on their radios ? Most people couldn't GIVE away an OEM radio
Old 02-01-2004, 04:22 PM
Re: Radio code
Good question. Honda OEM radios are not cheap at all. If some one steals an anti-theft radio it's useless unless they know some one to get the code. The dealer will not give out a code over the phone or with the radio only - Radio SN must match VIN.
Instead of stealing radio's airbags are hot items. I had a kid bring his car in with both air bags missing but aftermarket $400 radio, camera, & bunch of CD's untouched.
Old 02-01-2004, 04:34 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
airbags?
Old 02-01-2004, 07:43 PM
Re: Re: Radio code
Thanks Jackasssi,
I did find the code in the trunk of the car on a little white tag. It worked as advertised. Thanks again. \Cchast
Old 02-01-2004, 09:57 PM
Audio Guy
yea, airbags .... they are like $800 or some crap to replace them with a new one
Old 02-02-2004, 12:54 AM
Re: Re: Re: Radio code
Originally Posted by chast9693
Thanks Jackasssi,
Right on, now make sure to write down the code in a few places.
radio Codes for Legend factory radio robswinga Legend | RL 8 11-07-2010 05:42 PM
radio codes Atomik Car Audio 6 09-18-2007 08:42 PM
"97 galant" every 97 galant radio code is not 3844! here is what I did to get my code sallyjayd Galant 2 04-19-2005 12:11 PM
6th gen Radio codes speed-d3mon Accord/TSX/Accord Hybrid 3 04-30-2002 11:50 PM
Need Help with Radio Codes BertZ3 Accord/TSX/Accord Hybrid 4 03-07-2002 08:23 PM
