Old 02-01-2004, 01:19 PM
Krk_S15's Avatar
Krk_S15 Krk_S15 is offline
Send a message via MSN to Krk_S15
Thumbs up ! Brake Lite Flashing
Hey!
I would like 2 know if anyone has had this problem, I start my truck and the E-brake light is on i thought it could be my brake fluid is low or my ebrake is down but its not the case. Couple days later the light started flashing and has not stopped. anyone have a clue wut this could be from, broken sensor or somethin like that , thx 4 the help
[/quote]
Old 02-03-2004, 02:45 PM
rwulff rwulff is offline
I just bought my 89 blazer, and it does the same thing. I would love to know what causes this also. I too have checked the fluids and the ebrake, and everything looks ok to me.
Old 02-04-2004, 05:49 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
on the earlier trucks (90-87) with abs, the brake light will flash because of either an ABS failure or one of your brake light bulbs is out...
Old 02-04-2004, 06:26 AM
Its non-ABS and the brake lights are all fine. Any other thoughts?
Old 02-04-2004, 06:34 AM
rlith's Avatar
Re: ! Brake Lite Flashing
Hmm. How about the e-brake switch?
Old 02-04-2004, 06:36 AM
THats a thought. I might try dosconnecting the wire from the e brake, however, I have tried holding the pedal up with no luck.
Old 02-04-2004, 06:39 AM
rlith's Avatar
You may have to use a completely different switc, I can't remember if that switch is ground positive or not...
Old 06-15-2004, 02:22 PM
stampedemag stampedemag is offline
solution
I think that sometimes the computer gets a bad code due to low fluid level, loose connection, etc.
If there is no problem with the lights, ABS, or fluid level, disconnect the battery for 30 seconds and let the computer lose it's memory and then reconnect the battery. Check the light.
If it was a faulty code the light will not come on again. If it was a true code, write down the number of long and short flashes and then consult a Chevy mechanic. The number of flashes will represent the code that is
causing the light to come on.
Remember brakes are important!!! lol
