Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 02-01-2004, 11:22 AM
aboojum aboojum is offline
Question 2003 Jetta Auto shifter stuck in park in very cold weather
Has this happened to anyone? I took it to my dealer and he replaced a 'pin' (the receipt doesn't say what the pin is) and yet it still sticks until the car warms up.
Old 02-01-2004, 04:03 PM
jettaracer121212 jettaracer121212 is offline
yes this has happened to my friend it depends on how cold the weather is
Old 02-01-2004, 11:49 PM
tylerrules84 tylerrules84 is offline
Re: 2003 Jetta Auto shifter stuck in park in very cold weather
its a sensor in the transmission... i forget which one to be honest (not much help i know)... seems to be relatively common, happens in my friends Accord too.
I say thats what you get for buying an automatic, personally.
Driver Found.
Old 02-02-2004, 01:15 PM
boschmann boschmann is offline
The pin they refer to is probably a part of the shift lock solenoid which is adjustable. The system is probably working since you eventually get it out of park, it's just getting stuck. To adjust place in P or N, take off the trim cover and loosen the solenoid mounting screws. Insert a .019" feeler guage (about the thickness of a matchbook cover) between the shift lock solenoid push rod & shift lever (moving the solenoid if neccessary), then retighten the screws. I would try setting the adjustment cold & see if it still works when warm.
