Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 02-01-2004, 09:22 AM
Countrygirl Countrygirl is offline
Send a message via AIM to Countrygirl Send a message via Yahoo to Countrygirl
Question Check engine light on
I just purchased a 2000 Mystique with 86,000 miles on it. The check engine light just came on. I checked the oil and car isnt overheated . What could be the problem.? I read here I can take it to autozone and they will test it free. I guess its ok to drive it till I can get there.
Old 02-01-2004, 03:35 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
probably just a bad O2 sensor. have autozone pull the code for you.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-21-2004, 05:15 PM
madmax40965 madmax40965 is offline
Re: Check engine light on
country girl the check engine light has nothing to do with the oil or water temp. it mainly monitors all the sensors for emmissions and fuel.
It should be ok to drive with it on. If it is a problem that can damage the engine the light will blink.
madmax
Old 02-27-2004, 04:33 PM
MN88k1500 MN88k1500 is offline
Drove mine for nearly a year w/the light on until it finally started to stall out on us, idle rough and all that good stuff. Was the O2 (oxygen) sensor.
Old 02-28-2004, 01:49 AM
I think I would have gotten to the bottom of the problem of the check engine light being on before driving a year. A bad 02 sensor can burn up a tranny on it's own.
